path: root/cpukit/include/rtems/termiostypes.h (follow)
* Remove explicit file names from @fileSebastian Huber2019-02-281-1/+1
| | | | | | This makes the @file documentation independent of the actual file name. Update #3707.
* termios: Use self-contained objectsSebastian Huber2018-02-021-5/+8
| | | | Update #2840.
* Remove make preinstallChris Johns2018-01-251-0/+602
