brains GmbH.
This was requested to be executed prior to relicensing to BSD-2.
Updates #4625.
This reverts commit 8383572963e261ea384cddfa43cd9606e7c23cdd.
Update #3850
Close #3543.
The Telnet service started via rtems_telnetd_start() had a keep stdio
feature. This just created a task and executed the command function in
a loop. For this kind of service we do not library support. This can
be done by an application task on its own. Remove this feature and
provide only the real Telnet server functionality.
Use syslog() for error and status messages.
Add test program for the Telnet server.
Close #3542.
Add a rtems_telnetd_config_table::client_maximum member to the Telnet
configuration.
Close #3526.
Close #3528.
Add support for libbsd initialization.
Update #3419.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
* telnetd/telnetd.h: Spacing.
* Makefile.am, preinstall.am, libmisc/Makefile.am,
libmisc/shell/shell.c, libmisc/shell/shell.h, telnetd/check_passwd.c,
telnetd/telnetd.c, telnetd/telnetd.h:
Generalized login check.
* libmisc/shell/login.h, libmisc/shell/login_check.c,
libmisc/shell/login_prompt.c: New files.
* libmisc/stackchk/check.c: Changed format for blown stack message.
* libcsupport/src/libio_sockets.c: Removed superfluous cast.
* libnetworking/rtems/ftpfs.h: Documentation.
PR 1331/networking
* libmisc/shell/shell.c, telnetd/check_passwd.c, telnetd/telnetd.c,
telnetd/telnetd.h: Improve comments and explanation of options to
rtems_telnetd_initialize. Add extra newline to login sequence from
shell.
* telnetd/pty.c, telnetd/telnetd.c, telnetd/telnetd.h: Style clean up.
Now works on gen5200/icecube.
* telnetd/icmds.c, telnetd/pty.c, telnetd/telnetd.c, telnetd/telnetd.h:
Fix headers and formatting.
* telnetd/README, telnetd/pty.c, telnetd/pty.h, telnetd/telnetd.c,
telnetd/telnetd.h: telnetd rewrite.
* telnetd/check_passwd.c, telnetd/des.c, telnetd/genpw.c: New files.
* telnetd/icmds.c: Rename register_icmds to
_rtems_telnet_register_icmds. Make main_* functions static.
* telnetd/pty.c: Make many functions static.
Rename rtems_telnetd_maximum_ptys to rtems_pty_maximum_ptys.
* telnetd/pty.h: Reflect changes above.
Rename get_pty to rtems_pty_get. New header guards.
* telnetd/telnetd.c: Reflect changes above.
* telnetd/telnetd.h: New header guards.
* telnet/telnet.h, telnet/telnet.c: Rename
rtems_initialize_telnetd to rtems_telnetd_initialize,
main_telnetd to rtems_telnetd_main,
register_telnetd to rtems_telnetd_register.
* Makefile.am, configure.in, rtems_servers/Makefile.am,
rtems_servers/telnetd.c, rtems_servers/telnetd.h,
rtems_telnetd/Makefile.am, rtems_telnetd/README, rtems_telnetd/icmds.c,
rtems_telnetd/pty.c, rtems_telnetd/pty.h, rtems_telnetd/telnetd.c,
rtems_telnetd/telnetd.h, wrapup/Makefile.am:
- pty and telnetd have a new subdir rtems_telnetd to avoid
the side effect when ftpd change.
- the tcp/ip stats have been implemented into icmds.c and
started when telnetd daemon is started.
* rtems_servers/telnetd.c, rtems_servers/telnetd.h: Removed.
* rtems_telnetd: New directory.
* rtems_telnetd/Makefile.am, rtems_telnetd/README,
rtems_telnetd/icmds.c, rtems_telnetd/pty.c, rtems_telnetd/pty.h,
rtems_telnetd/telnetd.c, rtems_telnetd/telnetd.h: New files.
