* | cpukit/include/rtems: Change license to BSD-2 | Joel Sherrill | 2022-03-25 | 1 | -3/+22 |
| | | | | Updates #3053. | ||||
* | cpukit/: Scripted embedded brains header file clean up | Joel Sherrill | 2022-03-10 | 1 | -7/+1 |
| | | | | Updates #4625. | ||||
* | doxygen: Added subclasses to API | Andreas Dachsberger | 2019-04-04 | 1 | -0/+2 |
| | | | | | | | Update #3706. RTEMS Application Loader, RTEMS Runtime Link Editor, Status Checks and Test Support | ||||
* | Use rtems_task_exit() | Sebastian Huber | 2018-10-02 | 1 | -2/+2 |
| | | | | | Update #3530. Update #3533. | ||||
* | Include rtems/bspIo.h for printk. | Chris Johns | 2018-01-04 | 1 | -0/+2 |
| | | | | Closes @3267. | ||||
* | cpukit: Use Consistent Beginning of Doxygen Group Notation | Joel Sherrill | 2013-01-10 | 1 | -8/+4 |
| | | | | | This is the result of a sed script which converts all uses of @{ into a consistent form. | ||||
* | Header File Doxygen Enhancement Task #1 | Alex Ivanov | 2012-12-28 | 1 | -1/+1 |
* | Use proper 3 line form of license text | Joel Sherrill | 2012-10-11 | 1 | -2/+3 |
* | libnetworking/rtems/rtems_glue.c: Copy nothing if ↵ | Thomas Doerfler | 2008-10-10 | 1 | -85/+237 |
| | | | | | | rtems_bsdnet_parse_driver_name() if namep is NULL. include/rtems/status-checks.h: Added prefix "RTEMS" for all macros. Doxygen style comments. Cleanup. | ||||
* | 2008-08-20 Sebastian Huber <sebastian.huber@embedded-brains.de> | Joel Sherrill | 2008-08-20 | 1 | -2/+2 |
| | | | | * include/rtems/status-checks.h: Fixed integer conversion warning. | ||||
* | added BSP to m68k | Thomas Doerfler | 2008-07-11 | 1 | -3/+9 |
| | | | | adapted PPC exception code | ||||
* | 2008-07-10 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-07-10 | 1 | -132/+143 |
| | | | | * include/rtems/status-checks.h: Fix style. | ||||
* | Macros for status code and return value checks. | Thomas Doerfler | 2008-07-10 | 1 | -0/+176 |
