This makes the @file documentation independent of the actual file name.
Update #3707.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #2723.
The rtrace command interfaces to the RTEMS Trace Linker's trace
buffering data allowing users to capture and report trace data.
Make tables read-only.
Use a normal command for shutdown via exit().
This is a small (21K on sparc) editor that provides some powerful
features useful when a file needs editing on an embedded
board. No need to copy files off, edit, copy back.
This command lets you get an MD5 hash for a file in an RTEMS file system.
The ping code is taken from a recent FreeBSD release. Some options have been
tested, other not tested or do not work. This could be due to the age of
our TCP/IP stack.
This version of ping will not work if more than 64 file descriptors are
open at once because the select FD size is 64 as set in newlib.
o A new data structure rtems_filesystem_global_location_t was
introduced to be used for
o the mount point location in the mount table entry,
o the file system root location in the mount table entry,
o the root directory location in the user environment, and
o the current directory location in the user environment.
During the path evaluation global start locations are obtained to
ensure that the current file system instance will be not unmounted in
the meantime.
o The user environment uses now reference counting and is protected
from concurrent access.
o The path evaluation process was completely rewritten and simplified.
The IMFS, RFS, NFS, and DOSFS use now a generic path evaluation
method. Recursive calls in the path evaluation have been replaced
with iteration to avoid stack overflows. Only the evaluation of
symbolic links is recursive. No dynamic memory allocations and
intermediate buffers are used in the high level path evaluation. No
global locks are held during the file system instance specific path
evaluation process.
o Recursive symbolic link evaluation is now limited by
RTEMS_FILESYSTEM_SYMLOOP_MAX. Applications can retrieve this value
via sysconf().
o The device file system (devFS) uses now no global variables and
allocation from the workspace. Node names are allocated from the
heap.
o The upper layer lseek() performs now some parameter checks.
o The upper layer ftruncate() performs now some parameter checks.
o unmask() is now restricted to the RWX flags and protected from
concurrent access.
o The fchmod_h and rmnod_h file system node handlers are now a file
system operation.
o The unlink_h operation has been removed. All nodes are now destroyed
with the rmnod_h operation.
o New lock_h, unlock_h, clonenod_h, and are_nodes_equal_h file system
operations.
o The path evaluation and file system operations are now protected by
per file system instance lock and unlock operations.
o Fix and test file descriptor duplicate in fcntl().
o New test fstests/fsnofs01.
* libmisc/shell/main_mdump.c: Reworked to fix bugs in handling of the
length argument and to provide an "ldump" command. This file now also
supports the "wdump" command. In addition, an RTEMS API function called
rtems_mdump() is provided to allow easy dumping from application code.
* libmisc/shell/main_mwdump.c: Obsolete file.
* libmisc/Makefile.am: Removed main_mwdump.c
* libmisc/shell/shellconfig.h: Added "ldump" command.
* shell/memory.t: Added documentation for the "ldump" command
Signed-off-by: Ric Claus <claus@SLAC.Stanford.edu>
* include/rtems/bspIo.h, include/rtems/concat.h,
include/rtems/endian.h, include/rtems/fs.h, include/rtems/irq.h,
include/rtems/pci.h, include/rtems/userenv.h,
libblock/include/rtems/flashdisk.h,
libblock/include/rtems/nvdisk-sram.h,
libblock/include/rtems/nvdisk.h, libcsupport/include/clockdrv.h,
libcsupport/include/console.h, libcsupport/include/iosupp.h,
libcsupport/include/spurious.h,
libcsupport/include/motorola/mc68230.h,
libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/error.h,
libcsupport/include/rtems/framebuffer.h,
libcsupport/include/rtems/gxx_wrappers.h,
libcsupport/include/rtems/libcsupport.h,
libcsupport/include/rtems/libio_.h,
libcsupport/include/rtems/malloc.h,
libcsupport/include/rtems/termiostypes.h,
libcsupport/include/sys/statvfs.h, libcsupport/include/sys/termios.h,
libcsupport/include/sys/utsname.h, libcsupport/include/zilog/z8036.h,
libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h,
libfs/src/imfs/imfs.h, libfs/src/pipe/pipe.h,
libmisc/capture/capture-cli.h, libmisc/capture/capture.h,
libmisc/cpuuse/cpuuse.h, libmisc/devnull/devnull.h,
libmisc/devnull/devzero.h, libmisc/dumpbuf/dumpbuf.h,
libmisc/fb/fb.h, libmisc/fb/mw_uid.h, libmisc/mouse/mouse_parser.h,
libmisc/shell/shellconfig.h, libmisc/stringto/stringto.h,
libmisc/untar/untar.h, libnetworking/memory.h, posix/include/aio.h,
posix/include/mqueue.h, posix/include/semaphore.h,
posix/include/rtems/posix/aio_misc.h,
posix/include/rtems/posix/barrier.h,
posix/include/rtems/posix/cond.h, posix/include/rtems/posix/config.h,
posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h,
posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/posixapi.h,
posix/include/rtems/posix/ptimer.h,
posix/include/rtems/posix/rwlock.h,
posix/include/rtems/posix/sigset.h,
posix/include/rtems/posix/spinlock.h,
posix/inline/rtems/posix/barrier.inl,
posix/inline/rtems/posix/rwlock.inl,
posix/inline/rtems/posix/spinlock.inl,
posix/inline/rtems/posix/timer.inl, rtems/mainpage.h,
rtems/include/rtems/rtems/barrier.h,
rtems/include/rtems/rtems/object.h,
rtems/include/rtems/rtems/timer.h,
rtems/inline/rtems/rtems/barrier.inl,
rtems/inline/rtems/rtems/timer.inl,
rtems/src/semtranslatereturncode.c, sapi/include/rtems/config.h,
sapi/include/rtems/fatal.h, sapi/include/rtems/mptables.h,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/priority.inl: Add @file Doxygen directives
and descriptions to files which originated with RTEMS. This improves
the file list page generated by Doxygen.
* libcsupport/Makefile.am: Add mount-mgr.c.
* libcsupport/src/mount-mgr.c: New.
* include/rtems/fs.h: Added rtems_filesystem_location_mount.
* libcsupport/include/rtems/libio.h, libcsupport/src/mount.c: New
mount interface. It is similar to Linux.
* libcsupport/include/rtems/libio_.h: Remove the
init_fs_mount_table call.
* libcsupport/src/base_fs.c: Remove init_fs_mount_table_call. Use
the new mount call. Remove setting the root node in the global
pathloc. Mount does this now.
* libcsupport/src/privateenv.c: Remove the hack to set the root
mount table entry in the environment.
* libcsupport/src/unmount.cL Free the target string.
* libblock/src/bdpart-mount.c: New mount API.
* libfs/src/devfs/devfs.h, libfs/src/devfs/devfs_init.c,
libfs/src/dosfs/dosfs.h, libfs/src/dosfs/msdos.h,
libfs/src/dosfs/msdos_init.c, libfs/src/imfs/imfs.h,
libfs/src/imfs/imfs_eval.c, libfs/src/imfs/imfs_init.c,
libfs/src/imfs/miniimfs_init.c,
libfs/src/nfsclient/src/librtemsNfs.h,
libfs/src/rfs/rtems-rfs-rtems.c, libfs/src/rfs/rtems-rfs.h,
libnetworking/lib/ftpfs.c, libnetworking/rtems/ftpfs.h,
libnetworking/rtems/tftp.h: New mount_h API.
* libfs/src/devfs/devfs_eval.c: Local include of extern ops.
* libfs/src/nfsclient/src/nfs.c: New mount API. Removed the mount
me call and fixed the initialisation to happen when mounting.
* libmisc/Makefile.am, libmisc/shell/shellconfig.h: Remove mount
filesystem files.
* libmisc/fsmount/fsmount.c, libmisc/fsmount/fsmount.h: Updated to
the new mount table values.
* libmisc/shell/main_mount_ftp.c,
libmisc/shell/main_mount_msdos.c, libmisc/shell/main_mount_rfs.c,
libmisc/shell/main_mount_tftp.c: Removed.
* libmisc/shell/main_mount.c: Use the new mount API. Also access
the file system table for the file system types.
* libnetworking/lib/tftpDriver.c: Updated to the new mount
API. Fixed to allow mounting from any mount point. Also can now
have more than file system mounted.
* sapi/include/confdefs.h: Add file system configuration support.
* libmisc/shell/main_msdosfmt.c, libmisc/shell/shellconfig.h: Fix
the alias as I did understand how it worked.
* libfs/src/dosfs/msdos_format.c: Test for a block device.
* libblock/src/diskdevs.c: Create the devices as block devices.
* libmisc/shell/main_debugrfs.c, libmisc/shell/main_mkrfs.c,
libmisc/shell/main_mount_rfs.c: New.
* libmisc/shell/main_msdosfmt.c: Change the command to mkdos and
alias the old name.
* libmisc/shell/shellconfig.h, libmisc/Makefile.am: Add RFS
support.
* libfs/src/rfs/rtems-rfs-shell.c,
libfs/src/rfs/rtems-rfs-shell.h: Move the format command code into
the shell file.
* libmisc/shell/main_getenv.c, libmisc/shell/main_setenv.c,
libmisc/shell/main_unsetenv.c: New. The shell can now play with
environment variables.
* libmisc/Makefile.am, libmisc/shell/shellconfig.h: Add setenv,
getenv, and unsetenv to the shell.
* Makefile.am, preinstall.am: Added statvfs.h.
* libcsupport/Makefile.am: Add statvfs.c.
* libcsupport/include/sys/statvfs.h, libcsupport/src/statvfs.c:
New.
* libcsupport/include/rtems/libio.h: Add a file system handler for
the statvfs call.
* libfs/src/devfs/devfs_init.c, libfs/src/dosfs/msdos_init.c,
libfs/src/imfs/imfs_init.c, libfs/src/nfsclient/src/nfs.c: Set the
statvfs handler to NULL.
* include/rtems/fs.h: Add a second node access field for the RFS
file system to hold a directory offset while the existing field
holds the inode number. This save a rescan of the directory when
working with directories.
* libblock/include/rtems/bdbuf.h: Added references and user fields
to the buffer descriptor.
* libblock/src/bdbuf.c: Added dynamic buffer support for different
block sizes. Fixed a number of bugs.
* libblock/src/blkdev.c: Release the disk device on an error.
* libblock/src/diskdevs.c: Set the block size to the media block
size during initialisation of the disk device.
* libblock/src/flashdisk.c, libblock/src/nvdisk.c,
libblock/src/ramdisk.c: Updated the drivers to handle variable
block sizes.
* libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h: Release any
buffers when an error occurs. The FAT buffer layer hangs onto a
single buffer while mounted. This should be fixed.
* sapi/inline/rtems/chain.inl: Added rtems_chain_set_off_chain,
rtems_chain_is_node_off_chain, and rtems_chain_previous.
* score/inline/rtems/score/chain.inl: Added _Chain_Set_off_chain,
and _Chain_Is_node_off_chain.
* libmisc/shell/main_ln.c, libmisc/shell/main_mknod.c,
libmisc/shell/mknod-pack_dev.c, libmisc/shell/mknod-pack_dev.h:
New shell commands.
* libmisc/Makefile.am, libmisc/shell/shellconfig.h: Added ln and
mknod commands.
* libmisc/shell/hexdump-display.c: Fixed the reopen bug which
showed up as a free with a bad pointer.
* libmisc/shell/main_mount.c: List the user adding file system
when listing the available file systems to mount.
* libmisc/shell/utils-cp.c: Remove the fixed static copy buffer
and use a large dynamic buffer.
* score/inline/rtems/score/address.inl, score/src/coremsgsubmit.c,
score/src/objectallocate.c, score/src/objectfree.c: Remove
warnings.
* libmisc/shell/extern-dd.h: Delcare the conv arrays extern to
stop PPC link errors.
* libmisc/shell/main_time.c, libmisc/Makefile.am,
libmisc/shell/shellconfig.h: Add a time command.
* libmisc/shell/dd-args.c, libmisc/shell/dd-conv.c,
libmisc/shell/dd-conv_tab.c, libmisc/shell/dd-misc.c,
libmisc/shell/dd-position.c, libmisc/shell/dd.h,
libmisc/shell/extern-dd.h, libmisc/shell/hexdump-conv.c,
libmisc/shell/hexdump-display.c, libmisc/shell/hexdump-odsyntax.c,
libmisc/shell/hexdump-parse.c, libmisc/shell/hexdump.h,
libmisc/shell/hexsyntax.c, libmisc/shell/main_dd.c,
libmisc/shell/main_hexdump.c: New.
* libmisc/Makefile.am, libmisc/shell/shellconfig.h: Add dd and
hexdump commands.
* libcsupport/include/rtc.h: New RTC driver interface.
* libmisc/Makefile.am, libmisc/shell/shellconfig.h: Added RTC command.
* libmisc/shell/main_rtc.c: New file.
boolean values from 'int' to 'bool'. Added option 'login' to enable or
disable a login prompt. Changed intialization of global shell
environment to static initialization. Changed stack size type to
'size_t' conforming to classic API.
* libmisc/shell/shellconfig.h: Fixed some typos.
* libmisc/Makefile.am, libmisc/shell/shellconfig.h: Add halt command to
shell which results in the shutting RTEMS down.
* libmisc/shell/main_halt.c: New file.
* libcsupport/src/_rename_r.c: Fixed return code bug. Add a check
to see if the 'to' path was a directory and removed the directory.
* libmisc/Makefile.am, libmisc/shell/shellconfig.h: Added the mv command.
* libmisc/shell/main_mv.c, libmisc/shell/pathnames-mv.h: New.
* libmisc/shell/shellconfig.h, libmisc/stackchk/stackchk.h: Fix typos.
* libmisc/Makefile.am, libmisc/shell/main_cp.c,
libmisc/shell/main_cpuuse.c, libmisc/shell/main_date.c,
libmisc/shell/main_mallocinfo.c, libmisc/shell/main_netstats.c,
libmisc/shell/main_perioduse.c, libmisc/shell/main_stackuse.c,
libmisc/shell/main_wkspaceinfo.c, libmisc/shell/print_heapinfo.c,
libmisc/shell/shell.c, libmisc/shell/shell.h,
libmisc/shell/shell_makeargs.c, libmisc/shell/shellconfig.c,
libmisc/shell/shellconfig.h, libmisc/shell/write_file.c: Add initial
capability to automatically execute a script from the filesystem. Add
echo command from NetBSD and sleep command.
* libmisc/shell/main_echo.c, libmisc/shell/main_sleep.c,
libmisc/shell/shell_script.c: New files.
* libmisc/Makefile.am, libmisc/shell/shellconfig.h: Add netstats
command to access statistics reporting functions in TCP/IP stack.
* libmisc/shell/main_netstats.c: New file.
* libmisc/Makefile.am, libmisc/shell/main_wkspaceinfo.c,
libmisc/shell/shell.c, libmisc/shell/shellconfig.h: Add route and
ifconfig commands. The code for these was previously in the
networking guide. Disable NFS filesystem mount until that code is in
cpukit.
* libmisc/shell/main_ifconfig.c, libmisc/shell/main_route.c: New files.
* libmisc/Makefile.am: Add new files.
* libmisc/shell/internal.h: Prototype for rtems_shell_print_heap_info()
* libmisc/shell/main_mallocinfo.c: Use rtems_shell_print_heap_info().
* libmisc/shell/shellconfig.h: Add wkspace command.
* libmisc/shell/main_wkspaceinfo.c,
libmisc/shell/print_heapinfo.c: New files.
* configure.ac: fixed bug that always enabled strict order
mutexes.
* score/inline/rtems/score/coremutex.inl: Fixed coding standard.
* score/src/coremutex.c: Add the holder's thread to the lock_mutex
list if the mutex is initialised locked.
* libnetworking/rtems/rtems_glue.c: Changed semaphore error
message to show the error is an rtems-net error.
* libmisc/monitor/mon-network.c: Removed warnings.
* telnetd/icmds.c: Changed shell_* to rtems_shell_*.
* score/Makefile.am: Fixed typo that stopped 'make tags' working.
* libmisc/shell/err.c, libmisc/shell/err.h, libmisc/shell/errx.c,
libmisc/shell/extern-cp.h, libmisc/shell/fts.c,
libmisc/shell/fts.h, libmisc/shell/main_cp.c,
libmisc/shell/utils-cp.c, libmisc/shell/verr.c,
libmisc/shell/verrx.c, libmisc/shell/vwarn.c,
libmisc/shell/vwarnx.c, libmisc/shell/warn.c,
libmisc/shell/warnx.c: New. Ported from BSD.
* libmisc/shell/shellconfig.h: Add the cp command.
* libmisc/Makefile.am: Add the new files to the shell.
* libmisc/shell/shell.c, libmisc/shell/shell.h: Add scripting
support.
* libblock/src/flashdisk.c: Fixed disk drive count size setting
bug.
* libcsupport/Makefile.am, libcsupport/preinstall.am,
libcsupport/src/malloc.c, libcsupport/src/mallocinfo.c,
libmisc/Makefile.am, libmisc/shell/main_mallocinfo.c,
libmisc/shell/shellconfig.h: Split malloc.c into multiple files with
one function per file. Also split out statistics into a separate file
which can be plugged in dynamically. Right now, it is always in. I
suspect that splitting the file removed more code than leaving
statistics in. I tinkered with malloc information command in the
shell. I resurrected the malloc arena code as malloc boundary. This
code is now compiled all the time even though it does not appear to
* libcsupport/include/rtems/malloc.h, libcsupport/src/_calloc_r.c,
libcsupport/src/_free_r.c, libcsupport/src/_malloc_r.c,
libcsupport/src/_realloc_r.c, libcsupport/src/calloc.c,
libcsupport/src/free.c, libcsupport/src/malloc_boundary.c,
libcsupport/src/malloc_get_statistics.c,
libcsupport/src/malloc_initialize.c, libcsupport/src/malloc_p.h,
libcsupport/src/malloc_report_statistics.c,
libcsupport/src/malloc_report_statistics_plugin.c,
libcsupport/src/malloc_statistics_helpers.c,
libcsupport/src/malloc_walk.c, libcsupport/src/realloc.c,
libmisc/shell/main_perioduse.c: New files.
* libmisc/shell/main_alias.c, libmisc/shell/main_blksync.c,
libmisc/shell/main_cat.c, libmisc/shell/main_cd.c,
libmisc/shell/main_chdir.c, libmisc/shell/main_chmod.c,
libmisc/shell/main_chroot.c, libmisc/shell/main_cpuuse.c,
libmisc/shell/main_date.c, libmisc/shell/main_dir.c,
libmisc/shell/main_exit.c, libmisc/shell/main_help.c,
libmisc/shell/main_id.c, libmisc/shell/main_logoff.c,
libmisc/shell/main_ls.c, libmisc/shell/main_mallocinfo.c,
libmisc/shell/main_mdump.c, libmisc/shell/main_medit.c,
libmisc/shell/main_mfill.c, libmisc/shell/main_mkdir.c,
libmisc/shell/main_mmove.c, libmisc/shell/main_mount.c,
libmisc/shell/main_mount_ftp.c, libmisc/shell/main_mount_msdos.c,
libmisc/shell/main_mount_nfs.c, libmisc/shell/main_mount_tftp.c,
libmisc/shell/main_msdosfmt.c, libmisc/shell/main_mwdump.c,
libmisc/shell/main_pwd.c, libmisc/shell/main_rm.c,
libmisc/shell/main_rmdir.c, libmisc/shell/main_stackuse.c,
libmisc/shell/main_tty.c, libmisc/shell/main_umask.c,
libmisc/shell/main_unmount.c, libmisc/shell/main_whoami.c,
libmisc/shell/shell_cmdset.c, libmisc/shell/shellconfig.h: Change
rtems_Shell_ to rtems_shell_.
* libmisc/Makefile.am, libmisc/shell/shellconfig.h: Add malloc command
with info and dump as replacement for older command. Fix what looked
like a typo for mount sub-commands.
* libmisc/shell/main_mallocinfo.c: New file.
* libmisc/shell/main_mallocdump.c: Removed.
* libmisc/shell/main_blksync.c, libmisc/shell/main_msdosfmt.c,
libmisc/shell/main_unmount.c: New.
* libmisc/Makefile.am, libmisc/shell/shellconfig.h: Add the
blksync, msdosfmt, and unmount commands.
* libnetworking/rtems/tftp.h: Provide a decl to the TFTP file
system opts table.
* libnetworking/rtems/ftpfs.h: Provide a decl to the FTP file
system opts table.
* libmisc/Makefile.am: Add the mount command and supporting files.
* libmisc/preinstall.am: Rebuilt.
* libmisc/shell/cat_file.c, libmisc/shell/cmds.c,
libmisc/shell/main_alias.c, libmisc/shell/main_cat.c,
libmisc/shell/main_cd.c, libmisc/shell/main_chdir.c,
libmisc/shell/main_chmod.c, libmisc/shell/main_chroot.c,
libmisc/shell/main_dir.c, libmisc/shell/main_exit.c,
libmisc/shell/main_help.c, libmisc/shell/main_id.c,
libmisc/shell/main_logoff.c, libmisc/shell/main_ls.c,
libmisc/shell/main_mallocdump.c, libmisc/shell/main_mdump.c,
libmisc/shell/main_medit.c, libmisc/shell/main_mfill.c,
libmisc/shell/main_mkdir.c, libmisc/shell/main_mmove.c,
libmisc/shell/main_mwdump.c, libmisc/shell/main_pwd.c,
libmisc/shell/main_rm.c, libmisc/shell/main_rmdir.c,
libmisc/shell/main_stackuse.c, libmisc/shell/main_tty.c,
libmisc/shell/main_umask.c, libmisc/shell/main_whoami.c,
libmisc/shell/shell.c, libmisc/shell/shell_cmdset.c,
libmisc/shell/shell_makeargs.c, libmisc/shell/str2int.c,
libmisc/shell/write_file.c: Move all shell_* types, variables and
functions to rtems_shell_* to avoid namespace clashes with
applications. The is an RTEMS shell after all.
* libmisc/shell/shell.h, libmisc/shell/internal.h,
libmisc/shell/shellconfig.h: Move all shell_* types, variables and
applications. Add the mount command supporting types.
* libmisc/shell/main_mount.c, libmisc/shell/main_mount_ftp.c,
libmisc/shell/main_mount_msdos.c, libmisc/shell/main_mount_nfs.c,
libmisc/shell/main_mount_tftp.c: New.
* libmisc/Makefile.am, libmisc/shell/cat_file.c,
libmisc/shell/shell_makeargs.c, libmisc/shell/shellconfig.h: Rename
cmd_XXX.c to main_XXX.c. Add cpuuse and stackuse commands.
* libmisc/shell/main_alias.c, libmisc/shell/main_cat.c,
libmisc/shell/main_umask.c, libmisc/shell/main_whoami.c: New files.
* libmisc/shell/cmd_alias.c, libmisc/shell/cmd_cat.c,
libmisc/shell/cmd_cd.c, libmisc/shell/cmd_chdir.c,
libmisc/shell/cmd_chmod.c, libmisc/shell/cmd_chroot.c,
libmisc/shell/cmd_date.c, libmisc/shell/cmd_dir.c,
libmisc/shell/cmd_exit.c, libmisc/shell/cmd_help.c,
libmisc/shell/cmd_id.c, libmisc/shell/cmd_logoff.c,
libmisc/shell/cmd_ls.c, libmisc/shell/cmd_mallocdump.c,
libmisc/shell/cmd_mdump.c, libmisc/shell/cmd_medit.c,
libmisc/shell/cmd_mfill.c, libmisc/shell/cmd_mkdir.c,
libmisc/shell/cmd_mmove.c, libmisc/shell/cmd_mwdump.c,
libmisc/shell/cmd_pwd.c, libmisc/shell/cmd_rm.c,
libmisc/shell/cmd_rmdir.c, libmisc/shell/cmd_tty.c,
libmisc/shell/cmd_umask.c, libmisc/shell/cmd_whoami.c: Removed.
* libmisc/Makefile.am, libmisc/shell/cmd_help.c, libmisc/shell/cmds.c,
libmisc/shell/internal.h, libmisc/shell/shell.c,
libmisc/shell/shell.h, libmisc/shell/shellconfig.h: Command set
processing now separated from main command loop. Addition of user
commands and aliases tested. Monitor registration now explicit.
* libmisc/shell/shell_cmdset.c, libmisc/shell/shell_makeargs.c,
libmisc/shell/write_file.c: New files.
* ChangeLog, preinstall.am, libmisc/Makefile.am, libmisc/shell/cmds.c,
libmisc/shell/shell.c, libmisc/shell/shell.h: Split shell commands
into multiple files and add initial stages of command configuration.
This seems to work but the monitor commands need to be integrated
this way and the ability to configure user commands needs to be
tested.
* libmisc/shell/cat_file.c, libmisc/shell/cmd_alias.c,
libmisc/shell/cmd_cat.c, libmisc/shell/cmd_cd.c,
libmisc/shell/cmd_chdir.c, libmisc/shell/cmd_chmod.c,
libmisc/shell/cmd_chroot.c, libmisc/shell/cmd_date.c,
libmisc/shell/cmd_dir.c, libmisc/shell/cmd_exit.c,
libmisc/shell/cmd_help.c, libmisc/shell/cmd_id.c,
libmisc/shell/cmd_logoff.c, libmisc/shell/cmd_ls.c,
libmisc/shell/cmd_mallocdump.c, libmisc/shell/cmd_mdump.c,
libmisc/shell/cmd_medit.c, libmisc/shell/cmd_mfill.c,
libmisc/shell/cmd_mkdir.c, libmisc/shell/cmd_mmove.c,
libmisc/shell/cmd_mwdump.c, libmisc/shell/cmd_pwd.c,
libmisc/shell/cmd_rm.c, libmisc/shell/cmd_rmdir.c,
libmisc/shell/cmd_tty.c, libmisc/shell/cmd_umask.c,
libmisc/shell/cmd_whoami.c, libmisc/shell/internal.h,
libmisc/shell/shellconfig.c, libmisc/shell/shellconfig.h,
libmisc/shell/str2int.c: New files.
