path: root/cpukit/include/rtems/shellconfig.h (follow)
* shell: Add i2c and spi commandsChristian Mauderer2021-03-311-0/+28
| | | | | | | | | | This adds some commands that are usefull for debugging simple serial interfaces. Even if they are a complete re-implementation, the i2c* commands use a simmilar call like the Linux i2c tools. Closes #4371
* Remove explicit file names from @fileSebastian Huber2019-02-281-1/+1
| | | | | | This makes the @file documentation independent of the actual file name. Update #3707.
* Remove make preinstallChris Johns2018-01-251-0/+554
