path: root/cpukit/include/rtems/seterr.h (follow)
* rtems: Move "Set Errno" group to the APISebastian Huber2020-11-261-5/+5
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-2/+2
| | | | Update #3706
* Remove explicit file names from @fileSebastian Huber2019-02-281-1/+1
| | | | | | This makes the @file documentation independent of the actual file name. Update #3707.
* Remove make preinstallChris Johns2018-01-251-0/+53
