Ensure when both RTEMS_DEBUG is specified and pointers are large that
enough space is allocated to accomodate the Per_CPU_Control structure.
This changes the calculation to be more compositional instead of trying
to list out every permutation of options possible.
We have to use a second thread queue context to acquire and release the
thread wait lock.
Close #4356.
Priority ceiling semaphores (in contrast to MrsP semaphores) have only
one priority ceiling which is defined for the home scheduler of the task
which created the semaphore. Always check during a semaphore seize that
the home scheduler of the calling task is equal to this scheduler.
This avoids a scheduler mismatch if the semphore is acquired after the
calling thread blocked on the semaphore.
Allow the installation of an NTP update second handler which may be used by an
NTP service.
Update #2348.
This patch set replaces the CPU budget algorithm enumeration with a set of CPU
budget operations which implement a particular CPU budget algorithm. This
helps to hide the CPU budget algorithm implementation details from the general
thread handling. The CPU budget callouts are turned into CPU budget
operations. This slightly reduces the size of the thread control block.
All schedulers used the default scheduler tick implementation. The tick
scheduler operation is removed and the CPU budget operations are directly used
in _Watchdog_Tick() if the executing thread uses a CPU budget algorithm. This
is performance improvement for all threads which do not use a CPU budget
algorithm (default behaviour).
This adds a confdef option allowing an application to request mapping
machine exceptions to POSIX signals. This is required for some languages
such as Ada.
The rate monotonic period statistics were affected by
rtems_cpu_usage_reset(). The logic to detect and work around a CPU
usage reset was broken.
The Thread_Contol::cpu_time_used is changed to contain the processor
time used throughout the entire lifetime of the thread. The new member
Thread_Contol::cpu_time_used_at_last_reset is added to contain the
processor time used at the time of the last reset through
rtems_cpu_usage_reset(). This decouples the resets of the CPU usage and
the rate monotonic period statistics.
Update #4528.
Add a stack allocator hook specifically for allocation of IDLE thread stacks.
This allows the user to decide if IDLE thread stacks are statically allocated
or handled by the same custom allocator mechanism as other thread stacks.
Closes #4524.
Commit 18c8a270c296addff87f96b8c248f27eba31c24f removed
_Thread_queue_Do_nothing_extract() so we have to check for a non-NULL
queue in all configurations.
The schedule operation is only called by rtems_task_mode(). It is
called if preempt mode of the executing thread changes from disabled to
enabled. Since the EDF SMP scheduler does not support the disabled
preemption mode, the schedule operation is never called.
Define the group in the header file which is used by <rtems/confdefs.h>.
Update #3706.
Update #3706.
Replace the boolen return value with the new enum
Thread_queue_Deadlock_status. This improves the code readability.
Improve documentation. Shorten function names.
Reflect renamed specification item.
If SMP support is enabled and the system has exactly one processor, then
it may use an uniprocessor scheduler. The ask for help, reconsider help
request, and withdraw node operations can be NULL in this case, since
they are only used if a thread has at least one helping scheduler node.
At least two schedulers are required to get a helping node and each
scheduler involved must own at least one processor. This is not
possible on a system with exactly one processor.
Issue the new fatal SMP error
SMP_FATAL_SCHEDULER_REQUIRES_EXACTLY_ONE_PROCESSOR if the system starts
with not exactly one processor and an uniprocessor scheduler is
configured.
The uniprocessor schedulers do not support systems with more than more
processors. So they rivially support thread pinning and thus the
SMP_FATAL_SCHEDULER_PIN_OR_UNPIN_NOT_SUPPORTED cannot happen.
Add a second default implementation for SMP schedulers which do not
support thread pinning.
Change license to BSD-2-Clause according to file history and re-licensing
agreement.
Update #3053.
Rename SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY in
SCHEDULER_DEFAULT_SET_AFFINITY_OPERATION. Add Doxygen comment.
Rename SCHEDULER_OPERATION_DEFAULT_ASK_FOR_HELP in
SCHEDULER_DEFAULT_SMP_OPERATIONS. Add a Doxygen comment.
This simplifies the implementation a bit. Declare _TOD_Days_to_date[] in
<rtems/score/todimpl.h>. Make _TOD_Days_per_month[] and
_TOD_Days_since_last_leap_year[] static.
Update #4338.
Limit the CLOCK_REALTIME setting to ensure that the CLOCK_REALTIME is defined
for a system uptime of at least 114 years.
Move the TOD validation to the callers of _TOD_Set(). This avoids dead code in
case only rtems_clock_set() is used in an application because rtems_clock_set()
always calls _TOD_Set() with a valid time of day.
Use _Watchdog_Ticks_per_second instead.
In _Thread_queue_Flush_critical(), update the priority of the thread
queue owner only if necessary. The scheduler update priority operation
could be expensive.
This function was only used in one place. Replace it with a call to
_Thread_queue_Resume().
The _Thread_queue_First_locked() was only used in one place. Move the code of
this inline function to this place.
In order to ensure FIFO fairness across schedulers, the thread queue
surrender operation must be used to dequeue a thread from the thread
queue. The thread queue extract operation is intended for timeouts.
Add _Thread_queue_Resume() which may be used to make extracted or
surrendered threads ready again.
Remove the now unused _Thread_queue_Extract_critical() function.
Close #4509.
The priority queues in clustered scheduling configurations use a per
scheduler priority queue rotation to ensure FIFO fairness across
schedulers. This mechanism is implemented in the thread queue surrender
operation. Unfortunately some semaphore and message queue directives
used wrongly the thread queue extract operation. Fix this through the
use of _Thread_queue_Surrender().
Update #4358.
This helps to write tests for _Thread_Wait_for_execution_stop().
Rename Thread_Zombie_control in Thread_Zombie_registry.
The NULL pointer check for the executing thread was introduced by
commit:
commit be3c257286ad870d8d1a64941cde53fd2d33a633
Author: Sebastian Huber <sebastian.huber@embedded-brains.de>
Date: Thu Jun 5 11:17:26 2014 +0200
score: Avoid NULL pointer access
Check that the executing thread is not NULL in _Scheduler_Tick(). It
may be NULL in case the processor has an optional scheduler assigned and
the system was not able to start the processor.
However, it is no longer necessary since now the clock interrupt is
distributed to the online processors.
In SMP configurations, on 64-bit architectures use plain atomic
operations to set/get the priority value of a scheduler node. On 32-bit
architectures use an ISR lock. Using a sequence lock has no real
benefit since it uses atomic read-modify-write operations for both the
read and the write lock. Simply use a ticket lock instead so that only
one SMP synchronization primitive is used for everything.
Use the new Priority_Group_order enum instead of a boolean to indicated if a
priority should be inserted as the first or last node into its priority group.
This makes the code more expressive. It is also a bit more efficient since a
branch in _Scheduler_Node_set_priority() is avoided and a simple bitwise or
operation can be used.
Use the processor control to specify the target processor since this is what
the callers have available.
Remove the unused _SMP_Send_message_multicast() and
_SMP_Send_message_broadcast().
The per-CPU states which control the SMP system initialization were added quite
early during the SMP support development. Replace this initial implementation
with a simplified one. There is no longer a global SMP lock required which
serialized the state changes of all processors. The new implementation better
integrates with the per-CPU jobs.
Remove _CPU_SMP_Processor_event_broadcast() and
_CPU_SMP_Processor_event_receive(). These functions are hard to use since they
are subject to the lost wake up problem.
Users have access to the fatal error source and code though the fatal error
extension. The user-specific fatal error handling should be done in statically
initialized fatal error handlers. The _Internal_errors_What_happened was
updated after the fatal error extension. In addition, there was no API to get
the information stored in _Internal_errors_What_happened. In SMP
configurations, this object could contain a mix of different fatal errors.
Remove this object to save some bytes of storage.
Add RTEMS_FATAL_SOURCE_SPURIOUS_INTERRUPT as the fatal source for
spurious interrupts. Use the interrupt vector number of the spurious
interrupt for the fatal code.
Update #3269.
This change allows for the migration of higher priority tasks on the
arrival of a lower priority task limited by affinity constraints.
re-licensing agreement.
Update #3053.
Make the initialization of the per-CPU data optional.
Update #3053.
Set Thread_queue_Context::timeout_absolute in
_Thread_queue_Context_set_timeout_argument() to avoid using it uninitialized.
The bug was introduced by a89ecaa1a94d49ddae7753d6b83923e9d2a00486.
