Add _ISR_lock_Set_name() to optimize the initialization of
zero-initialized locks.
Rename _SMP_Get_processor_count() in _SMP_Get_processor_maximum() to be
in line with the API level rtems_scheduler_get_processor_maximum().
Update #3732.
Rename _SMP_Processor_count in _SMP_Processor_maximum to be in line with
Update #3732.
Close #3734.
This is intended as an example in the RTEMS Software Engineering manual.
Update #3704.
Update #3706
They are intended as examples in the RTEMS Software Engineering manual.
Update #3704.
Update #3706.
Update #3706.
Update #3706.
Update #3706.
This makes the @file documentation independent of the actual file name.
Update #3707.
Recursive usage of the same pthread_once_t results now in a deadlock.
Previously, an error of EINVAL was returned. This usage scenario is
invalid according to the POSIX pthread_once() specification.
Close #3334.
We have to read the first node again once we obtained the lock since it
may have aready changed.
Add low level event recording infrastructure for system and user
defined events. The infrastructure is able to record high frequency
events such as
* SMP lock acquire/release,
* interrupt entry/exit,
* thread switches,
* UMA zone allocate/free, and
* Ethernet packet input/output, etc.
It allows post-mortem analysis in fatal error handlers, e.g. the last
events are in the record buffer, the newest event overwrites the oldest
event. It is possible to detect record buffer overflows for consumers
that expect a continuous stream of events, e.g. to display the system
state in real-time.
The implementation supports high-end SMP machines (more than 1GHz
processor frequency, more than four processors).
Add a new API instead. The implementation uses per-processor data
structures and no atomic read-modify-write operations. It is uses
per-processor ring buffers to record the events.
The CPU counter is used to get the time of events. It is combined with
periodic uptime events to synchronize it with CLOCK_REALTIME.
The existing capture engine tries to solve this problem also, but its
performance is not good enough for high-end production systems. The
main issues are the variable-size buffers and the use of SMP locks for
synchronization. To fix this, the API would change significantly.
Update #3665.
Ensure that interrupts are disabled while acquiring an ISR lock.
The CPU_ALIGNMENT must not be zero, this is also checked via a static
assertion. Fix formatting.
Allocate the per-CPU data for secondary processors directly from the
heap areas before heap initialization and not via
_Workspace_Allocate_aligned(). This avoids dependency on the workspace
allocator. It fixes also a problem on some platforms (e.g. QorIQ) where
at this early point in the system initialization the top of the RAM is
used by low-level startup code on secondary processors (boot pages).
Update #3507.
Statically allocate the objects information together with the initial
set of objects either via <rtems/confdefs.h>. Provide default object
informations with zero objects via librtemscpu.a. This greatly
simplifies the workspace size estimate. RTEMS applications which do not
use the unlimited objects option are easier to debug since all objects
reside now in statically allocated objects of the right types.
Close #3621.
Use Objects_Information::objects_per_block to provide this information.
Add and use _Objects_Is_auto_extend().
Update #3621.
Remove Objects_Information::the_class. This information is already
contained in Objects_Information::maximum_id.
Update #3621.
This information is already present in Objects_Information::maximum_id.
Add and use _Objects_Get_maximum_index().
Update #3621.
Use the maximum ID for the ID to object translation. Using the maximum
ID gets rid of an additional load from the object information in
_Objects_Get(). In addition, object lookups fail for every ID in case
the object information is cleared to zero. This makes it a bit more
robust during system startup (see new tests in spconfig02).
The local table no longer needs a NULL pointer entry at array index
zero. Adjust all the object iteration loops accordingly.
Remove Objects_Information::minimum_id since it contains only redundant
information. Add _Objects_Get_minimum_id() to get the minimum ID.
Update #3621.
Rename Objects_Information::allocation_size in
Objects_Information::objects_per_block. Adjust integer types in
_Objects_Shrink_information() and _Objects_Free().
Update #3621.
Rename Objects_Information::size to Objects_Information::object_size.
Change its type from size_t to uint16_t and move it to reduce the size
of Objects_Information.
Update #3621.
Use Objects_Information::name_length to store this information.
Update #3621.
The sbintime_t is a non-POSIX type and not visible if strict standard
options are selected.
Move implementation details from <rtems/score/timestamp.h> to
<rtems/score/timestampimpl.h>.
Update #3598.
Enable the use of RTEMS_DEVOLATILE() and RTEMS_DECONST() in strict ISO C
environments.
Remove <rtems/score/chainimpl.h> include from
<rtems/score/smplockstats.h>.
Close #3598.
Move Heap_Information_block to separate header file to hide heap
implementation details from <rtems.h>.
Update #3598.
The RTEMS_USE_16_BIT_OBJECT define is not set by an RTEMS port. Remove
support for 16-bit object identifiers. If someone really wants to use
RTEMS on a 16-bit target, then it is better to use self-contained
objects instead of playing around with object identifier optimizations.
Update #3603.
Update #3583.
Update #3585.
Update #3598.
Include implementation header files only if necessary.
Update #3598.
Update #3598.
Update #3598.
Separate the definitions related to watchdog ticks from the watchdog
structures.
Update #3598.
Update #3598.
Update #3598.
Update #3584.
This function was only used on some m68k variants. On these m68k
variants there is no need to use a global symbol. Use a local label
instead.
Remove _ISR_Dispatch() from the architecture-independent layer.
Rename
* _Configuration_Interrupt_stack_area_begin in _ISR_Stack_area_begin,
* _Configuration_Interrupt_stack_area_end in _ISR_Stack_area_end, and
* _Configuration_Interrupt_stack_size in _ISR_Stack_size.
Move definitions to <rtems/score/isr.h>. The new names are considerable
shorter and in the right namespace.
Update #3459.
Reduce structure internal padding. Group members used by _Objects_Get()
together. Reduce size of some members.
Format and simplify _Objects_Extend_information().
