brains GmbH.
Define the group in the header file which is used by <rtems/confdefs.h>.
Update #3706.
Adjust group identifier and names to be in line with a common pattern.
Use common phrases for the group and file brief descriptions.
Update #3706.
Before this patch RTEMS_Malloc_Initialize() had a fixed dependency on
_Workspace_Area. Introduce _Workspace_Malloc_initializer to have this
dependency only if CONFIGURE_UNIFIED_WORK_AREAS is defined by the
application configuration.
Move the unified workspace configuration constant out of the
configuration table.
Provide a default definition of the unified workspace constant.
Update #3875.
Move the workspace size configuration constant out of the configuration
table.
Update #3875.
Move the idle thread body configuration constant out of the
Provide a default definition of the idle thread body constant.
Update #3875.
Move the idle thread stack size configuration constant out of the
Add THREAD_IDLE_STACK_SIZE_DEFAULT and use it to provide a default
definition of the idle thread stack size constant.
Update #3875.
controller support.
Update #3269.
This is an example test using the RTEMS Test Framework. It tests also
the framework itself.
Add T_FILE_NAME command line define to get rid of the full file path.
This is important to reduce the read-only data of test files and make
them build system independent.
Update #3199.
