path: root/cpukit/include/rtems/score/wkspace.h (follow)
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-2/+2
| | | | Update #3706
* doxygen: Rework some Doxygen commentsSebastian Huber2019-04-041-10/+7
| | | | | | They are intended as examples in the RTEMS Software Engineering manual. Update #3704.
* Remove explicit file names from @fileSebastian Huber2019-02-281-1/+1
| | | | | | This makes the @file documentation independent of the actual file name. Update #3707.
* Remove make preinstallChris Johns2018-01-251-0/+138
