The BSPs provide memory for the workspace initialization via
_Memory_Get(). Most BSPs provide exactly one memory area. Only two
BSPs provide more than one memory area (arm/altera-cyclone-v and
bsps/powerpc/mpc55xxevb). Only if more than one memory area is
provided, there is a need to use _Heap_Extend(). Provide two
implementations to initialize the workspace handler and let the BSP
select one of the implementations based on the number of provided memory
areas. This gets rid of a dependency on _Heap_Extend(). It also avoids
dead code sections for most BSPs.
Define the group in the header file which is used by <rtems/confdefs.h>.
Update #3706.
Use common phrases for the file brief descriptions.
Update #3706.
Adjust group identifier and names to be in line with a common pattern.
Use common phrases for the group brief descriptions.
Update #3706.
The work area initialization was done by the BSP through
bsp_work_area_initialize(). This approach predated the system
initialization through the system initialization linker set. The
workspace and C program heap were unconditionally initialized. The aim
is to support RTEMS application configurations which do not need the
workspace and C program heap. In these configurations, the workspace
and C prgram heap should not get initialized.
Change all bsp_work_area_initialize() to implement _Memory_Get()
instead. Move the dirty memory, sbrk(), per-CPU data, workspace, and
malloc() heap initialization into separate system initialization steps.
This makes it also easier to test the individual initialization steps.
This change adds a dependency to _Heap_Extend() to all BSPs. This
dependency will be removed in a follow up change.
Update #3838.
This function is unused.
Update #3735.
Update #3706.
Update #3706
They are intended as examples in the RTEMS Software Engineering manual.
Update #3704.
This makes the @file documentation independent of the actual file name.
Update #3707.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
