path: root/cpukit/include/rtems/score/watchdogticks.h (follow)
* score: Canonicalize Doxygen @file commentsSebastian Huber2020-12-021-1/+3
| | | | | | Use common phrases for the file brief descriptions. Update #3706.
* config: Add _Watchdog_Ticks_per_timesliceSebastian Huber2020-02-251-0/+13
| | | | | | | | | | Move the ticks per timeslice configuration constant out of the configuration table. Add WATCHDOG_TICKS_PER_TIMESLICE_DEFAULT and use it to provide a default definition of the watchdog ticks per timeslice constant. Update #3875.
* config: Add _Watchdog_Microseconds_per_tickSebastian Huber2020-02-251-0/+8
| | | | | | | | | | Move the microseconds per tick configuration constant out of the configuration table. Add WATCHDOG_MICROSECONDS_PER_TICK_DEFAULT and use it to provide a default definition of the watchdog ticks constants. Update #3875.
* doxygen: score: adjust doc in watchdogticks.h to doxygen guidelinesAndreas Dachsberger2019-05-131-0/+2
| | | | Update #3706.
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-2/+2
| | | | Update #3706
* score: Introduce <rtems/score/watchdogticks.h>Sebastian Huber2018-11-121-0/+73
Separate the definitions related to watchdog ticks from the watchdog structures. Update #3598.
