path: root/cpukit/include/rtems/score/watchdog.h (follow)
* doxygen: score: adjust doc in watchdog.h to doxygen guidelinesAndreas Dachsberger2019-05-131-14/+17
| | | | Update #3706.
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-3/+3
| | | | Update #3706
* score: Introduce <rtems/score/watchdogticks.h>Sebastian Huber2018-11-121-36/+3
| | | | | | | Separate the definitions related to watchdog ticks from the watchdog structures. Update #3598.
* score: Introduce new monotonic clockSebastian Huber2018-02-021-9/+0
| | | | | | | | Rename PER_CPU_WATCHDOG_MONOTONIC to PER_CPU_WATCHDOG_TICKS. Add new PER_CPU_WATCHDOG_MONOTONIC which is based on the system uptime (measured by timecounter). Close #3264.
* Remove make preinstallChris Johns2018-01-251-0/+166
