path: root/cpukit/include/rtems/score/watchdog.h (follow)
* score: Introduce new monotonic clockSebastian Huber2018-02-021-9/+0
| | | | | | | | Rename PER_CPU_WATCHDOG_MONOTONIC to PER_CPU_WATCHDOG_TICKS. Add new PER_CPU_WATCHDOG_MONOTONIC which is based on the system uptime (measured by timecounter). Close #3264.
* Remove make preinstallChris Johns2018-01-251-0/+166
