path: root/cpukit/include/rtems/score/userextimpl.h (follow)
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-2/+2
| | | | Update #3706
* doxygen: Reviewed cpukit/include/rtems/scoreAndreas Dachsberger2019-04-021-7/+3
| | | | Update #3706.
* score: Fix _User_extensions_Thread_switch() (SMP)Sebastian Huber2019-02-081-3/+11
| | | | | We have to read the first node again once we obtained the lock since it may have aready changed.
* score: Move internal structures to userextdata.hSebastian Huber2018-11-121-1/+1
| | | | Update #3598.
* score: Avoid include of <rtems/score/thread.h>Sebastian Huber2018-11-121-1/+2
| | | | Update #3598.
* Remove make preinstallChris Johns2018-01-251-0/+369
