path: root/cpukit/include/rtems/score/userext.h (follow)
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-3/+3
| | | | Update #3706
* score: Move internal structures to userextdata.hSebastian Huber2018-11-121-23/+0
| | | | Update #3598.
* score: Avoid include of <rtems/score/thread.h>Sebastian Huber2018-11-121-14/+15
| | | | Update #3598.
* Remove make preinstallChris Johns2018-01-251-0/+273
