* score/include/rtems/score/tod.h: Declare _TOD_Set_with_timestamp()
and _TOD_Get_as_timestamp().
* score/src/coretodset.c: Define _TOD_Set_with_timestamp().
* score/src/coretodget.c: Define _TOD_Get_as_timestamp().
* rtems/src/clockset.c: Use _TOD_Set_with_timestamp().
* score/include/rtems/score/timestamp64.h, score/src/ts64set.c:
Changed parameter types of _Timestamp64_Set().
* rtems/src/clocktodtoseconds.c: Year 2100 is not a leap year.
* rtems/include/rtems/rtems/types.h,
score/include/rtems/score/address.h,
score/include/rtems/score/apiext.h,
score/include/rtems/score/bitfield.h,
score/include/rtems/score/context.h,
score/include/rtems/score/corerwlock.h,
score/include/rtems/score/coresem.h,
score/include/rtems/score/corespinlock.h,
score/include/rtems/score/interr.h, score/include/rtems/score/isr.h,
score/include/rtems/score/mpci.h, score/include/rtems/score/mppkt.h,
score/include/rtems/score/objectmp.h,
score/include/rtems/score/percpu.h,
score/include/rtems/score/rbtree.h,
score/include/rtems/score/scheduler.h,
score/include/rtems/score/smp.h, score/include/rtems/score/smplock.h,
score/include/rtems/score/stack.h,
score/include/rtems/score/states.h,
score/include/rtems/score/threadq.h,
score/include/rtems/score/threadsync.h,
score/include/rtems/score/timespec.h,
score/include/rtems/score/timestamp.h,
score/include/rtems/score/tod.h, score/include/rtems/score/tqdata.h,
score/include/rtems/score/watchdog.h,
score/include/rtems/score/wkspace.h: Mark Score files as in Score
Group to improve Doxygen output.
* libcsupport/include/rtems/malloc.h, libmisc/stackchk/stackchk.h,
posix/include/rtems/posix/time.h, rtems/include/rtems/rtems/object.h,
score/include/rtems/score/interr.h, score/include/rtems/score/mpci.h,
score/include/rtems/score/threadmp.h,
score/include/rtems/score/wkspace.h: Make @brief formatting more
consistent.
* score/include/rtems/score/rbtree.h: Also reformat.
* score/include/rtems/score/tod.h: Add missing includes.
* score/include/rtems/score/tod.h: Fix typo.
* score/include/rtems/score/tod.h: Correct name of parameter.
* sapi/include/rtems/extension.h, sapi/include/rtems/io.h,
sapi/src/exinit.c, sapi/src/extension.c, sapi/src/io.c,
score/include/rtems/score/mpci.h, score/include/rtems/score/object.h,
score/include/rtems/score/thread.h, score/include/rtems/score/tod.h,
score/include/rtems/score/userext.h,
score/include/rtems/score/wkspace.h, score/src/coretod.c,
score/src/mpci.c, score/src/object.c, score/src/thread.c,
score/src/userext.c, score/src/wkspace.c: Convert SAPI manager and
SuperCore Handler initialization routines to directly pull parameters
from configuration table.
* libblock/src/bdbuf.c, libmisc/capture/capture-cli.c,
libmisc/capture/capture.c, libmisc/mw-fb/mw_uid.c,
rtems/include/rtems/rtems/support.h, score/Makefile.am,
score/include/rtems/score/tod.h, score/src/coretod.c,
score/src/coretodtickle.c: Eliminate all public use of TOD conversion
routines. Eliminate _TOD_Microseconds_per_tick and let every place
use the field directly from the Configuration Table. This required
moving some methods from macros to bodies.
* score/src/coretodmsecstoticks.c, score/src/coretodtickspersec.c,
score/src/coretodusectoticks.c: New files.
* libcsupport/src/__times.c, libmisc/cpuuse/cpuusagereport.c,
libmisc/cpuuse/cpuusagereset.c, posix/src/clockgettime.c,
posix/src/pthread.c, posix/src/timersettime.c,
rtems/src/clockgetsecondssinceepoch.c, rtems/src/clockgetuptime.c,
rtems/src/ratemongetstatus.c, rtems/src/ratemonperiod.c,
rtems/src/ratemonreportstatistics.c, rtems/src/taskwakewhen.c,
rtems/src/timerfirewhen.c, rtems/src/timerserver.c,
rtems/src/timerserverfirewhen.c, score/Makefile.am,
score/preinstall.am, score/include/rtems/score/thread.h,
score/src/coretodget.c, score/src/coretodgetuptime.c,
score/src/coretodset.c, score/src/coretodtickle.c,
score/src/threaddispatch.c, score/src/threadinitialize.c: Add
SuperCore handler Timestamp to provide an opaque class for the
representation and manipulation of uptime, time of day, and the
difference between two timestamps. By using SuperCore Timestamp, it
is clear which methods and APIs really have to be struct timespec and
which can be in an optimized native format.
* score/include/rtems/score/timestamp.h,
score/src/coretodgetuptimetimespec.c: New files.
* score/Doxyfile: Update to latest Doxygen format.
* score/include/rtems/score/apimutex.h,
score/include/rtems/score/heap.h, score/include/rtems/score/object.h,
score/include/rtems/score/protectedheap.h,
score/inline/rtems/score/corerwlock.inl,
score/inline/rtems/score/corespinlock.inl: Remove most doxygen
warnings.
* itron/src/itrontime.c: Fix typo.
* score/include/rtems/score/tod.h: Add TOD_TICKS_PER_SECOND macro.
* score/src/iterateoverthreads.c: Safely take NULL as argument.
* score/src/threaddispatch.c: Formatting.
* posix/Makefile.am, posix/include/rtems/posix/time.h,
posix/src/adjtime.c, posix/src/alarm.c, posix/src/clockgetres.c,
posix/src/condtimedwait.c, posix/src/mqueuetimedreceive.c,
posix/src/mqueuetimedsend.c, posix/src/mutextimedlock.c,
posix/src/nanosleep.c, posix/src/posixtimespecabsolutetimeout.c,
posix/src/pthread.c, posix/src/pthreadcreate.c,
posix/src/pthreadsetschedparam.c, posix/src/ptimer1.c,
posix/src/sched.c, posix/src/semtimedwait.c,
posix/src/sigtimedwait.c, posix/src/ualarm.c,
rtems/src/clocktodtoseconds.c, score/Makefile.am,
score/preinstall.am, score/include/rtems/score/tod.h,
score/inline/rtems/score/tod.inl, score/src/coretod.c,
score/src/coretodset.c, score/src/coretodtickle.c: Provide timespec
manipulation routines in the SuperCore. Use them everywhere possible.
This lead to significant cleanup in the API routines and eliminated
some of the same code from the POSIX API. At this point, the
SuperCore keeps time in POSIX timespec format properly from 1970. You
just cannot set it before 1988 in keeping with RTEMS traditional
behavior.
* score/include/rtems/score/timespec.h, score/src/timespecaddto.c,
score/src/timespecfromticks.c, score/src/timespecisvalid.c,
score/src/timespeclessthan.c, score/src/timespecsubtract.c,
score/src/timespectoticks.c: New files.
* posix/src/posixintervaltotimespec.c,
posix/src/posixtimespecsubtract.c,
posix/src/posixtimespectointerval.c: Removed.
* score/Makefile.am, score/include/rtems/score/tod.h,
score/inline/rtems/score/tod.inl: Make _TOD_Tickle_ticks a real
non-inlined routine. It should only be used once so there is little
advantage to inlining it.
* score/src/coretodtickle.c: New file.
* posix/include/rtems/posix/timer.h, posix/src/alarm.c,
posix/src/posixtimespectointerval.c, posix/src/ptimer1.c,
posix/src/sysconf.c, posix/src/ualarm.c, rtems/src/clockget.c,
rtems/src/clocktodvalidate.c, score/include/rtems/score/tod.h,
score/inline/rtems/score/tod.inl, score/src/coretod.c: Eliminate
TOD_Ticks_per_second variable.
* itron/src/itrontime.c, libcsupport/src/__gettod.c,
posix/src/clockgettime.c, posix/src/clocksettime.c,
posix/src/nanosleep.c, posix/src/posixtimespecsubtract.c,
posix/src/sleep.c, rtems/Makefile.am,
rtems/include/rtems/rtems/clock.h, rtems/include/rtems/rtems/timer.h,
rtems/include/rtems/rtems/types.h, rtems/src/clockget.c,
rtems/src/clockset.c, rtems/src/clocktodtoseconds.c,
rtems/src/clocktodvalidate.c, rtems/src/taskwakewhen.c,
score/src/coretodset.c: Convert from Classic API style TOD_Control as
fundamental time structure to POSIX struct timespec. Add
clock_get_uptime().
* rtems/src/clockgetuptime.c, score/src/coretodget.c,
score/src/coretodgetuptime.c: New files.
* score/src/coretodtickle.c, score/src/coretodtoseconds.c,
score/src/coretodvalidate.c: Removed.
Large patch to improve Doxygen output. As a side-effect, grammar and
spelling errors were corrected, spacing errors were address, and some
variable names were improved.
* libmisc/monitor/mon-object.c, libmisc/monitor/monitor.h:
Account for changing OBJECTS_NO_CLASS to OBJECTS_CLASSIC_NO_CLASS.
* score/Doxyfile: Set output directory. Predefine some macro values.
Turn on graphical output.
* score/include/rtems/debug.h, score/include/rtems/seterr.h,
score/include/rtems/system.h, score/include/rtems/score/address.h,
score/include/rtems/score/chain.h,
score/include/rtems/score/heap.h, score/include/rtems/score/interr.h,
score/include/rtems/score/isr.h, score/include/rtems/score/mpci.h,
score/include/rtems/score/sysstate.h,
score/include/rtems/score/threadq.h, score/include/rtems/score/tod.h,
score/inline/rtems/score/address.inl,
score/inline/rtems/score/chain.inl,
score/inline/rtems/score/coremutex.inl,
score/inline/rtems/score/coresem.inl,
score/inline/rtems/score/heap.inl,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/stack.inl,
score/inline/rtems/score/thread.inl,
score/inline/rtems/score/tqdata.inl, score/macros/README,
score/src/heap.c, score/src/threadmp.c, score/src/threadready.c,
score/src/threadstartmultitasking.c: Improve generated Doxygen
output. Fix spelling and grammar errors in comments. Correct names of
some variables and propagate changes.
* score/cpu/no_cpu/rtems/score/cpu.h, score/include/rtems/debug.h,
score/include/rtems/seterr.h, score/include/rtems/system.h,
score/include/rtems/score/copyrt.h,
score/inline/rtems/score/coremsg.inl,
score/inline/rtems/score/heap.inl, score/inline/rtems/score/isr.inl,
score/inline/rtems/score/mppkt.inl,
score/inline/rtems/score/objectmp.inl,
score/inline/rtems/score/priority.inl,
score/inline/rtems/score/states.inl,
score/inline/rtems/score/sysstate.inl,
score/inline/rtems/score/threadmp.inl,
score/inline/rtems/score/userext.inl,
score/inline/rtems/score/watchdog.inl,
score/inline/rtems/score/wkspace.inl: Add Doxygen comments -- working
modifications which are not complete and may have broken code.
Committing so work and testing can proceed.
* score/Doxyfile, score/mainpage.h: New files.
* score/include/rtems/debug.h, score/include/rtems/score/bitfield.h,
score/inline/rtems/score/wkspace.inl,
score/macros/rtems/score/address.inl,
score/macros/rtems/score/heap.inl,
score/macros/rtems/score/object.inl,
score/macros/rtems/score/priority.inl,
score/macros/rtems/score/userext.inl: Convert to using c99 fixed
size types.
* include/rtems/score/object.h, include/rtems/score/tod.h:
Added casts to eliminate warnings on 16 bit targets like the h8300.
>> >>There is a 30 day error in _TOD_Days_since_last_leap_year[2..3]
>> >Thanks.
>> >What's the condition to hit this error?
>> >Every year 4n+2 and 4n+3 ?
>> >(i.e. 1998, 1999, 2002, 2003, ...)
>> OK: 96 97 00 01 04 05 ...
>> Bad: 98 99 02 03 06 07 ...
There is also a problem in newlib 1.7.x reported at the same time:
>> I found another, that would strike only on 2/29/2000, or other leapyears.
>> Only a problem on 1 day.
>> Joel: FYI, there is a bug in Newlib localtime.c, localtime or (_tm_time).
>> Ours is modified for dst and timezones, but the bug was in original source.
>> I have not looked at the latest public source (nor do I know where to find
>> it).
in the unix port idle thread task. This should keep the entire application
from blocking when any component does a blocking application. Also added
TOD_MICROSECONDS_TO_TICKS.
Handler could timestamp the starting and stopping of timers. Since
TOD is built on top of Watchdog, this avoided a circular dependency.
like signal dispatching.
