path: root/cpukit/include/rtems/score/timecounter.h (follow)
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-3/+3
| | | | Update #3706
* score: Avoid sbintime_t in API headersSebastian Huber2018-12-071-1/+1
| | | | | | | | | | The sbintime_t is a non-POSIX type and not visible if strict standard options are selected. Move implementation details from <rtems/score/timestamp.h> to <rtems/score/timestampimpl.h>. Update #3598.
* Remove make preinstallChris Johns2018-01-251-0/+244
