path: root/cpukit/include/rtems/score/timecounter.h (follow)
* score: Canonicalize Doxygen @file commentsSebastian Huber2020-12-021-1/+2
| | | | | | Use common phrases for the file brief descriptions. Update #3706.
* score: Canonicalize Doxygen groupsSebastian Huber2020-12-021-1/+1
| | | | | | | Adjust group identifier and names to be in line with a common pattern. Use common phrases for the group brief descriptions. Update #3706.
* Add TOD Hooks to allow BSP to take action when TOD is setJoel Sherrill2019-12-111-0/+10
| | | | | | | | | | | | Two use cases were envisioned for this. 1) a BSP or application which desires to update a real-time clock when the RTEMS TOD is set. 2) a paravirtualized BSP can use this to propagate setting the time in an RTEMS application to the hosting environment. This enables the entire set of applications in the virtualized environments to have a single consistent TOD.
* doxygen: score: adjust doc in timecounter.h to doxygen guidelinesAndreas Dachsberger2019-05-131-5/+7
| | | | Update #3706.
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-3/+3
| | | | Update #3706
* score: Avoid sbintime_t in API headersSebastian Huber2018-12-071-1/+1
| | | | | | | | | | The sbintime_t is a non-POSIX type and not visible if strict standard options are selected. Move implementation details from <rtems/score/timestamp.h> to <rtems/score/timestampimpl.h>. Update #3598.
* Remove make preinstallChris Johns2018-01-251-0/+244
