path: root/cpukit/include/rtems/score/threadq.h (follow)
* score: Constify Thread_queue_First_operationSebastian Huber2021-02-061-6/+7
| | | | Update #4230.
* score: Canonicalize Doxygen @file commentsSebastian Huber2020-12-021-4/+3
| | | | | | Use common phrases for the file brief descriptions. Update #3706.
* score: Canonicalize Doxygen groupsSebastian Huber2020-12-021-1/+1
| | | | | | | Adjust group identifier and names to be in line with a common pattern. Use common phrases for the group brief descriptions. Update #3706.
* doxygen: score: adjust doc in threadq.h to doxygen guidelinesAndreas Dachsberger2019-05-131-11/+16
| | | | Update #3706.
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-2/+2
| | | | Update #3706
* score: Static Objects_Information initializationSebastian Huber2018-12-141-9/+0
| | | | | | | | | | | Statically allocate the objects information together with the initial set of objects either via <rtems/confdefs.h>. Provide default object informations with zero objects via librtemscpu.a. This greatly simplifies the workspace size estimate. RTEMS applications which do not use the unlimited objects option are easier to debug since all objects reside now in statically allocated objects of the right types. Close #3621.
* score: Introduce <rtems/score/watchdogticks.h>Sebastian Huber2018-11-121-1/+3
| | | | | | | Separate the definitions related to watchdog ticks from the watchdog structures. Update #3598.
* Remove make preinstallChris Johns2018-01-251-0/+595
