Directly use "static inline" which is available in C99 and later. This brings
the RTEMS implementation closer to standard C.
Close #3935.
The rtems_task_delete() directive is basically just a combined pthread_cancel()
and pthread_join(). In addition, it removes the PTHREAD_DETACHED state. The
exit value returned by pthread_join() of threads cancelled by
rtems_task_delete() should reflect this by getting a PTHREAD_CANCELED value
instead of NULL which could be a normal exit value.
Close #4680.
Threads may join the thread termination of another thread using the
pthread_join() or rtems_task_delete() directives. The thread cancel operation
used a special case priority boosting mechanism implemented by
_Thread_Raise_real_priority(). The problem was that this approach
* is not transitive,
* does not account for priority adjustments of the calling task
while waiting for the join,
* does not support clustered scheduling, and
* does not detect deadlocks.
All these problems are fixed by using a priority inheritance thread queue for
the join operation.
Close #4679.
This function is only used in SMP configurations.
Updates #3053.
The _Thread_queue_Extract() does not deal with potential priority
updates and the SMP locking protocol handling. Use
_Thread_queue_Continue(). For the POSIX signals processing this is
currently probably unnecessary, however, the use case is similar to the
restart so use the same appoach.
Close #4546.
Remove the THREAD_WAIT_STATE_READY_AGAIN and simply use the initial value to
indicate that a thread does not wait on something. Rename
THREAD_WAIT_FLAGS_INITIAL to THREAD_WAIT_STATE_READY. This change is necessary
so that _Thread_Continue() can be called for threads which never waited on
something (for example dormant threads).
Update #4546.
Remove _Thread_queue_Extract_with_proxy() and move the proxy extraction
to _Thread_MP_Extract_proxy(). Move similar code blocks of the previous
caller of _Thread_queue_Extract_with_proxy() to helper functions.
Update #4546.
Process ask for help requests on the current processor. This avoids
using inter-processor interrupts to make the system behaviour a bit more
predictable.
Update #4531.
This patch fixes the following broken behaviour:
While a thread is scheduled on a helping scheduler, while it does not
own a MrsP semaphore, if it obtains a MrsP semaphore, then no
scheduler node using an idle thread and the ceiling priority of the
semaphore is unblocked for the home scheduler.
This could lead to priority inversion issues and is not in line
with the MrsP protocol.
Introduce two new scheduler operations which are only enabled if
RTEMS_SMP is defined. The operations are used to make the scheduler
node of the home scheduler sticky and to clean the sticky property.
This helps to keep the sticky handing out of the frequently used
priority update operation.
Close #4532.
This patch set replaces the CPU budget algorithm enumeration with a set of CPU
budget operations which implement a particular CPU budget algorithm. This
helps to hide the CPU budget algorithm implementation details from the general
thread handling. The CPU budget callouts are turned into CPU budget
operations. This slightly reduces the size of the thread control block.
All schedulers used the default scheduler tick implementation. The tick
scheduler operation is removed and the CPU budget operations are directly used
in _Watchdog_Tick() if the executing thread uses a CPU budget algorithm. This
is performance improvement for all threads which do not use a CPU budget
algorithm (default behaviour).
The rate monotonic period statistics were affected by
rtems_cpu_usage_reset(). The logic to detect and work around a CPU
usage reset was broken.
The Thread_Contol::cpu_time_used is changed to contain the processor
time used throughout the entire lifetime of the thread. The new member
Thread_Contol::cpu_time_used_at_last_reset is added to contain the
processor time used at the time of the last reset through
rtems_cpu_usage_reset(). This decouples the resets of the CPU usage and
the rate monotonic period statistics.
Update #4528.
Commit 18c8a270c296addff87f96b8c248f27eba31c24f removed
_Thread_queue_Do_nothing_extract() so we have to check for a non-NULL
queue in all configurations.
This helps to write tests for _Thread_Wait_for_execution_stop().
Rename Thread_Zombie_control in Thread_Zombie_registry.
Use the new Priority_Group_order enum instead of a boolean to indicated if a
priority should be inserted as the first or last node into its priority group.
This makes the code more expressive. It is also a bit more efficient since a
branch in _Scheduler_Node_set_priority() is avoided and a simple bitwise or
operation can be used.
Move common code into _Thread_Exit(). This enables a tail call
optimization in most cases.
rtems_task_restart() may be called from within interrupt context. So
checking only that the thread to restart is equal to the executing
thread is insufficient to determine a self restart. We have to also
check that no ISR is in progress. Merge _Thread_Restart_other() and
_Thread_Restart_self() into one _Thread_Restart() since they share a lot
of common code.
Close #4412.
This simplifies rtems_task_restart().
Rename _Stack_Free_nothing() in _Objects_Free_nothing() to make it
reusable for the message queue buffers.
Update #4007.
This may reduce the code size a bit.
This avoids having conditional statements to get the API-specific status
code.
Move the CPU time budget to the thread configuration. This simplifies
_Thread_Initialize().
Close the thread object if a thread create extension fails. Also call
the delete extension to avoid resource leaks in early extensions if a
late extension fails.
Close #4270.
Use the type safe _Objects_Open_u32() instead. Return the object
identifier to enforce a common usage pattern.
Update #4244.
We do not need all the checks if we have a valid indentifier to a thread
class object.
Using the new _Thread_Get_objects_information() instead of the inline
function _Thread_Get_objects_information_by_id() avoids dead code since
the identifier in a thread control is always valid and the return NULL
path in _Thread_Get_objects_information_by_id() would be dead code. The
_Thread_Get_objects_information_by_id() should be an inline function
since it is used by _Thread_Get() and thus performance critical. Static
analyzers which cannot derive that the identifier in a thread control is
always valid, may find a potential NULL pointer access (or otherwise
find dead code).
The identifier in an object control is always valid, see
_Objects_Initialize_information() and _Objects_Extend_information().
Move _RTEMS_tasks_Free() to the only source file which calls this
function.
Rename _Thread_Get_objects_information() in
_Thread_Get_objects_information_by_id() to emphasize that this thread
method uses an object identifier and not a thread control.
Use common phrases for the file brief descriptions.
Update #3706.
Simply compare the values against NULL.
Provide RTEMS_NO_RETURN also in case RTEMS_DEBUG is defined to prevent errors
like this:
error: no return statement in function returning non-void [-Werror=return-type]
Use C11 and C++11 standard means to declare a no-return function.
Close #4122.
This avoids a dependency to the stack free function in the thread
destruction.
Update #3959.
Move thread stack allocation to caller side of _Thread_Initialize().
Update #3835.
Add the Thread_Configuration structure to reduce the parameter count of
_Thread_Initialize(). This makes it easier to add more parameters in
the future. It simplifies the code generation since most architectures
do not have that many registers available for function parameters.
Update #3835.
Update #3835.
Remove superfluous Thread_Control::Start::stack member.
Update #3835.
Remove THREAD_STATUS_PROXY_BLOCKING and replace it with
STATUS_PROXY_BLOCKING.
Add and use _Thread_Get_unmapped_real_priority().
Update #3706.
The use of a hand crafted lock for Per_CPU_Control::Lock was necessary
at some point in the SMP support development, but it is no longer
justified.
Update #3706
Statically allocate the objects information together with the initial
set of objects either via <rtems/confdefs.h>. Provide default object
informations with zero objects via librtemscpu.a. This greatly
simplifies the workspace size estimate. RTEMS applications which do not
use the unlimited objects option are easier to debug since all objects
reside now in statically allocated objects of the right types.
Close #3621.
The sbintime_t is a non-POSIX type and not visible if strict standard
options are selected.
Move implementation details from <rtems/score/timestamp.h> to
<rtems/score/timestampimpl.h>.
Update #3598.
Update #2514.
Add support to temporarily pin a thread to its current processor. This
may be used to access per-processor data structures in critical sections
with enabled thread dispatching, e.g. a pinned thread is allowed to
block.
Update #3508.
This was spotted by Coverity Scan.
