Updates #3053.
The __builtin_unreachable() cannot be used with current GCC versions to
tell the compiler that a function does not return to the caller, see:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=99151
Add a no return variant of _Thread_Dispatch_direct() to avoid generation
of dead code.
Use common phrases for the file brief descriptions.
Update #3706.
Update #3706.
Update #3706
This function is slighly too complex for inlining with two if
statements. The caller already needs a stack frame due to the potential
call to _Thread_Do_dispatch(). In _Thread_Dispatch_enable() the call to
_Thread_Do_dispatch() can be optimized to a tail call.
A text size comparision
(text size after patch - text size before patch)
/ text size before patch
on sparc/erc32 with SMP enabled showed these results:
Minimum -0.000697892 (fsdosfsname01.exe)
Median -0.00745021 (psxtimes01.exe)
Maximum -0.0233032 (spscheduler01.exe)
Minimum -3312 (ada_sp09.exe)
Median -1024 (tm15.exe)
Maximum -592 (spglobalcon01.exe)
This bug had probably no effect since the interrupt enable is idempotent
on all CPU ports.
Close #3496.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
