Require that the corresponding lock is acquired before the action
handler returns. This helps to avoid recursion in the signal
processing.
Update #4244.
Use common phrases for the file brief descriptions.
Update #3706.
Adjust group identifier and names to be in line with a common pattern.
Use common phrases for the group brief descriptions.
Update #3706.
Add this application configuration option. This configuration option can be
used to reserve space for the dynamic linking of modules with thread-local
storage objects.
Add RTEMS_TASK_STORAGE_ALIGNMENT to define the minium alignment of a
thread-local storage size.
Update #4074.
This avoids a dependency to the stack free function in the thread
destruction.
Update #3959.
This type was deprecated in RTEMS 5.1.
Close #3991.
The IO library used a POSIX key to store an optional POSIX user
environment pointer. This pulled in the POSIX keys support in every
application configuration. Add a user environment pointer to the thread
control block (TCB) instead. Applications which do not need the POSIX
user environment will just get an overhead of one pointer per thread.
Close #3882.
Allocate new thread queue heads during objects information extend. This
removes an error case and the last dependency on the workspace in
_Thread_Initialize().
Update #3835.
Split up the different objects free methods into separate functions.
This helps to avoid a dependency on the workspace in case no objects or
a static set of objects is configured.
Update #3835.
Split up the different objects allocation methods into separate
functions. This helps to avoid a dependency on the workspace in case no
objects or a static set of objects is configured.
Change license to BSD-2-Clause according to file histories.
Update #3053.
Update #3835.
Place idle and MPCI stacks into extra linker sections. This can be
optionally used by applications to control the placement of the stacks.
Update #3835.
Move thread stack allocation to caller side of _Thread_Initialize().
Update #3835.
Update #3835.
Remove superfluous Thread_Control::Start::stack member.
Update #3835.
Update #3735.
Update #3706.
Update #3706
This makes the @file documentation independent of the actual file name.
Update #3707.
Statically allocate the objects information together with the initial
set of objects either via <rtems/confdefs.h>. Provide default object
informations with zero objects via librtemscpu.a. This greatly
simplifies the workspace size estimate. RTEMS applications which do not
use the unlimited objects option are easier to debug since all objects
reside now in statically allocated objects of the right types.
Close #3621.
Update #3598.
Update #2514.
Remove the CPU_PROVIDES_IDLE_THREAD_BODY option to avoid unnecessary
conditional compilation.
Close #3539.
Add support to temporarily pin a thread to its current processor. This
may be used to access per-processor data structures in critical sections
with enabled thread dispatching, e.g. a pinned thread is allowed to
block.
Update #3508.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
