In case the processor set is not large enough to contain the processor
affinity set of the task return RTEMS_INVALID_SIZE instead of
RTEMS_INVALID_NUMBER. This is more in line with other directives since
the issue is related to the size of an object.
Close #4393.
Replace Objects_Name_or_id_lookup_errors with new Status_Control codes.
Get rid of the _Status_Object_name_errors_to_status lookup table.
The value of STATUS_CLASSIC_INTERNAL_ERROR must be equal to
RTEMS_INTERNAL_ERROR. Add static assertions to ensure that the status
codes match.
Use common phrases for the file brief descriptions.
Update #3706.
Return a status code and differentiate between error conditions.
Update #4007.
Do not cast to unsigned int to avoid an unsigned long long enum type.
Use a multiplication/division instead to preserve the signedness of the
POSIX status.
Modify the status code returned by _CORE_message_queue_Submit() when it
detects a wait about to happen in an ISR (which would be deadly) to
return a status which translated to EAGAIN instead of ENOMEM.
This is only relevant for POSIX message queues, since Classic API message
queues cannot block on send.
The motivation is to match the "most related" errno value returned from
mq_send() and mq_timedsend() according to POSIX, via Open Group:
[EAGAIN]
The O_NONBLOCK flag is set in the message queue description
associated with mqdes, and the specified message queue is full.
or via the RTEMS POSIX users documentation
EAGAIN
The message queue is non-blocking, and there is no room on the queue
for another message as specified by the mq_maxmsg.
Neither of these matches the case ofi avoided ISR wait perfectly, but
they seem to be the closest equivalent, unless it is desirable to keep a
new non-standard error for this case. It is presumed that this is not
desirable.
The previously returned ENOMEM error value is not documented in either
the Open Group or the RTEMS POSIX uses documentation. A companion patch
corrects the documentation to include this error condition.
Based on the discussion in:
https://lists.rtems.org/pipermail/devel/2020-January/056891.html
closes #3857.
Message-Id: <CAF9ehCW5P12ZkZja4UPYTbdBFUyC1VKVL-tU7nyUtvK1Lz2Z3g@mail.gmail.com>
Remove THREAD_STATUS_PROXY_BLOCKING and replace it with
STATUS_PROXY_BLOCKING.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
