Updates #3053.
Use common phrases for the file brief descriptions.
Update #3706.
Adjust group identifier and names to be in line with a common pattern.
Use common phrases for the group brief descriptions.
Update #3706.
Update #3706.
Update #3706
This makes the @file documentation independent of the actual file name.
Update #3707.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Move implementation specific parts of states.h and states.inl into new
header file statesimpl.h. The states.h contains now only the
application visible API.
The output of the modules.html is much improved. Most
filesystem and POSIX API related groups are properly nested.
Some formatting issues were addressed as were multiple
inconsistencies.
System events are similar to normal events. They offer a second set of
events. These events are intended for internal RTEMS use and should not
be used by applications (with the exception of the transient system
event).
* rtems/include/rtems/rtems/types.h,
score/include/rtems/score/address.h,
score/include/rtems/score/apiext.h,
score/include/rtems/score/bitfield.h,
score/include/rtems/score/context.h,
score/include/rtems/score/corerwlock.h,
score/include/rtems/score/coresem.h,
score/include/rtems/score/corespinlock.h,
score/include/rtems/score/interr.h, score/include/rtems/score/isr.h,
score/include/rtems/score/mpci.h, score/include/rtems/score/mppkt.h,
score/include/rtems/score/objectmp.h,
score/include/rtems/score/percpu.h,
score/include/rtems/score/rbtree.h,
score/include/rtems/score/scheduler.h,
score/include/rtems/score/smp.h, score/include/rtems/score/smplock.h,
score/include/rtems/score/stack.h,
score/include/rtems/score/states.h,
score/include/rtems/score/threadq.h,
score/include/rtems/score/threadsync.h,
score/include/rtems/score/timespec.h,
score/include/rtems/score/timestamp.h,
score/include/rtems/score/timestamp64.h,
score/include/rtems/score/tod.h, score/include/rtems/score/tqdata.h,
score/include/rtems/score/watchdog.h,
score/include/rtems/score/wkspace.h: Mark Score files as in Score
Group to improve Doxygen output.
score/inline/rtems/score/coresem.inl: Add SuperCore Barriers,
SpinLocks and a partial implementation of RWLocks.
* score/include/rtems/score/corebarrier.h,
score/inline/rtems/score/corebarrier.inl,
score/inline/rtems/score/corerwlock.inl,
score/inline/rtems/score/corespinlock.inl,
score/macros/rtems/score/corebarrier.inl,
score/macros/rtems/score/corerwlock.inl,
score/macros/rtems/score/corespinlock.inl, score/src/corebarrier.c,
score/src/corebarrierrelease.c, score/src/corebarrierwait.c,
score/src/corespinlock.c, score/src/corespinlockrelease.c,
score/src/corespinlockwait.c: New files.
Large patch to improve Doxygen output. As a side-effect, grammar and
spelling errors were corrected, spacing errors were address, and some
variable names were improved.
* libmisc/monitor/mon-object.c, libmisc/monitor/monitor.h:
Account for changing OBJECTS_NO_CLASS to OBJECTS_CLASSIC_NO_CLASS.
* score/Doxyfile: Set output directory. Predefine some macro values.
Turn on graphical output.
* score/include/rtems/debug.h, score/include/rtems/seterr.h,
score/include/rtems/system.h, score/include/rtems/score/address.h,
score/include/rtems/score/apimutex.h,
score/include/rtems/score/chain.h,
score/include/rtems/score/heap.h, score/include/rtems/score/interr.h,
score/include/rtems/score/isr.h, score/include/rtems/score/mpci.h,
score/include/rtems/score/sysstate.h,
score/include/rtems/score/threadmp.h,
score/include/rtems/score/threadq.h, score/include/rtems/score/tod.h,
score/include/rtems/score/userext.h,
score/include/rtems/score/wkspace.h,
score/inline/rtems/score/address.inl,
score/inline/rtems/score/chain.inl,
score/inline/rtems/score/coremutex.inl,
score/inline/rtems/score/coresem.inl,
score/inline/rtems/score/heap.inl,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/stack.inl,
score/inline/rtems/score/thread.inl,
score/inline/rtems/score/tqdata.inl, score/macros/README,
score/src/heap.c, score/src/threadmp.c, score/src/threadready.c,
score/src/threadstartmultitasking.c: Improve generated Doxygen
output. Fix spelling and grammar errors in comments. Correct names of
some variables and propagate changes.
* score/cpu/no_cpu/rtems/score/cpu.h, score/include/rtems/debug.h,
score/include/rtems/seterr.h, score/include/rtems/system.h,
score/include/rtems/score/copyrt.h,
score/inline/rtems/score/coremsg.inl,
score/inline/rtems/score/heap.inl, score/inline/rtems/score/isr.inl,
score/inline/rtems/score/mppkt.inl,
score/inline/rtems/score/objectmp.inl,
score/inline/rtems/score/priority.inl,
score/inline/rtems/score/states.inl,
score/inline/rtems/score/sysstate.inl,
score/inline/rtems/score/threadmp.inl,
score/inline/rtems/score/tod.inl,
score/inline/rtems/score/userext.inl,
score/inline/rtems/score/watchdog.inl,
score/inline/rtems/score/wkspace.inl: Add Doxygen comments -- working
modifications which are not complete and may have broken code.
Committing so work and testing can proceed.
* score/Doxyfile, score/mainpage.h: New files.
* score/include/rtems/debug.h, score/include/rtems/score/bitfield.h,
score/inline/rtems/score/wkspace.inl,
score/macros/rtems/score/address.inl,
score/macros/rtems/score/heap.inl,
score/macros/rtems/score/object.inl,
score/macros/rtems/score/priority.inl,
score/macros/rtems/score/userext.inl: Convert to using c99 fixed
size types.
can not be part of the locally blocked set since it by itself does not
indicate that the thread is blocked.
like signal dispatching.
