path: root/cpukit/include/rtems/score/states.h (follow)
* score: Canonicalize Doxygen @file commentsSebastian Huber2020-12-021-3/+3
| | | | | | Use common phrases for the file brief descriptions. Update #3706.
* score: Canonicalize Doxygen groupsSebastian Huber2020-12-021-1/+1
| | | | | | | Adjust group identifier and names to be in line with a common pattern. Use common phrases for the group brief descriptions. Update #3706.
* states*.h: Fix naming inconsistency and formattingJoel Sherrill2019-12-111-1/+1
* doxygen: score: adjust doc in stackimpl.h to doxygen guidelinesAndreas Dachsberger2019-05-131-9/+14
| | | | Update #3706.
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-2/+2
| | | | Update #3706
* Remove explicit file names from @fileSebastian Huber2019-02-281-1/+1
| | | | | | This makes the @file documentation independent of the actual file name. Update #3707.
* Remove make preinstallChris Johns2018-01-251-0/+50
