Rename _Stack_Free_nothing() in _Objects_Free_nothing() to make it
reusable for the message queue buffers.
Update #4007.
Do not adjust the stack area begin address since this may confuse the
stack allocator and result in failed stack frees.
Account for the alignment overhead in the stack space size estimate.
Check that the stack size is in the expected interval.
Make sure that a user-provided stack size is the minimum size allocated
for the stack.
Make sure we meet the stack alignment requirement also for CPU ports
with CPU_STACK_ALIGNMENT > CPU_HEAP_ALIGNMENT.
Check for an integer overflow. Add a validation test for task create
errors.
Use common phrases for the file brief descriptions.
Update #3706.
This avoids a dependency to the stack free function in the thread
destruction.
Update #3959.
Update #3835.
Use the stack area to allocate the TLS area.
Update #3835.
Use the stack area to allocate the FP context. This considerably
simplifies the application configuration since the task count no longer
influences the configured work space size. With this change the stack
space size is overestimated since an FP context for each thread is
accounted. Memory constraint applications can use the stack size for
fine tuning.
Update #3835.
Update #3835.
Remove superfluous Thread_Control::Start::stack member.
Update #3835.
Update #3706.
Update #3706
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
