Updates #3053.
Add a stack allocator hook specifically for allocation of IDLE thread stacks.
This allows the user to decide if IDLE thread stacks are statically allocated
or handled by the same custom allocator mechanism as other thread stacks.
Closes #4524.
Use common phrases for the file brief descriptions.
Update #3706.
Adjust group identifier and names to be in line with a common pattern.
Use common phrases for the group brief descriptions.
Update #3706.
Do the stack allocator initialization and sanity check only if a
user-provided stack allocator was configured. This avoids a dependency
of _Thread_Handler_initialization() on the stack allocator.
Update #3959.
This allows the linker garbage collection to perform its work.
Update #3835.
Use the stack area to allocate the TLS area.
Update #3835.
Update #3706.
Update #3706
This makes the @file documentation independent of the actual file name.
Update #3707.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
