path: root/cpukit/include/rtems/score/smplockticket.h (follow)
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-2/+2
| | | | Update #3706
* Remove make preinstallChris Johns2018-01-251-0/+187
