path: root/cpukit/include/rtems/score/smplockstats.h (follow)
* doxygen: score: adjust doc in smplockstats.h to doxygen guidelinesAndreas Dachsberger2019-05-131-5/+45
| | | | Update #3706.
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-2/+2
| | | | Update #3706
* score: <rtems/score/smplockstats.h>Sebastian Huber2018-11-261-17/+17
| | | | | | | Remove <rtems/score/chainimpl.h> include from <rtems/score/smplockstats.h>. Close #3598.
* score: Includes in <rtems/score/smplockstats.h>Sebastian Huber2018-11-121-0/+2
| | | | | | Include implementation header files only if necessary. Update #3598.
* Remove make preinstallChris Johns2018-01-251-0/+277
