path: root/cpukit/include/rtems/score/smplockmcs.h (follow)
* cpukit/include/rtems/score/[s-z]*.h: Change license to BSD-2Joel Sherrill2022-02-281-3/+22
| | | | Updates #3053.
* score: Canonicalize Doxygen @file commentsSebastian Huber2020-12-021-1/+2
| | | | | | Use common phrases for the file brief descriptions. Update #3706.
* doxygen: score: adjust doc in smplockmcs.h to doxygen guidelinesAndreas Dachsberger2019-05-131-7/+14
| | | | Update #3706.
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-2/+2
| | | | Update #3706
* Remove make preinstallChris Johns2018-01-251-0/+262
