This fix relates to a Coverity issue
(PW.USELESS_TYPE_QUALIFIER_ON_RETURN_TYPE).
Use common phrases for the file brief descriptions.
Update #3706.
Adjust group identifier and names to be in line with a common pattern.
Use common phrases for the group brief descriptions.
Update #3706.
Provide RTEMS_NO_RETURN also in case RTEMS_DEBUG is defined to prevent errors
like this:
error: no return statement in function returning non-void [-Werror=return-type]
Use C11 and C++11 standard means to declare a no-return function.
Close #4122.
Test for the proper system condition instead of using the
rtems_configuration_is_smp_enabled() workaround.
Update #3876.
All uses were replaced by per-processor jobs.
Use _SMP_Multicast_action() instead.
Move resposibility to disable thread dispatching to the caller of
_SMP_Multicast_action(). Using an interrupt disable for this purpose is
questionable.
Update #3706.
Let it work during system initialization.
Use a FIFO list of jobs per processor to carry out the SMP multicast
action. Use a done indicator per job to reduce the bus traffic a bit.
Processor_mask is the internal data type to deal with processor sets.
Update #3706
Update #3706.
Add support to temporarily pin a thread to its current processor. This
may be used to access per-processor data structures in critical sections
with enabled thread dispatching, e.g. a pinned thread is allowed to
block.
Update #3508.
Optimize _SMP_Inter_processor_interrupt_handler() for the common case in
which the inter-processor interrupt is only used to trigger a thread
dispatch.
Pass current processor control as first parameter to make dependency
more explicit.
Pass current processor control via parameter since it may be already
available at the caller side.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
