path: root/cpukit/include/rtems/score/smp.h (follow)
* doxygen: score: adjust doc in smp.h to doxygen guidelinesAndreas Dachsberger2019-05-131-0/+2
| | | | Update #3706.
* score: Rename _SMP_Get_processor_count()Sebastian Huber2019-04-111-2/+2
| | | | | | | Rename _SMP_Get_processor_count() in _SMP_Get_processor_maximum() to be in line with the API level rtems_scheduler_get_processor_maximum(). Update #3732.
* score: Rename _SMP_Processor_countSebastian Huber2019-04-111-2/+2
| | | | | | | Rename _SMP_Processor_count in _SMP_Processor_maximum to be in line with the API level rtems_scheduler_get_processor_maximum(). Update #3732.
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-3/+3
| | | | Update #3706
* Remove make preinstallChris Johns2018-01-251-0/+64
