path: root/cpukit/include/rtems/score/schedulersmpimpl.h (follow)
* doxygen: score: adjust doc in schedulersmpimpl.h to doxygen guidelinesAndreas Dachsberger2019-05-131-31/+377
| | | | Update #3706.
* score: Use an ISR lock for Per_CPU_Control::LockSebastian Huber2019-04-121-5/+7
| | | | | | The use of a hand crafted lock for Per_CPU_Control::Lock was necessary at some point in the SMP support development, but it is no longer justified.
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-2/+2
| | | | Update #3706
* score: Add thread pin/unpin supportSebastian Huber2018-09-101-0/+9
| | | | | | | | | Add support to temporarily pin a thread to its current processor. This may be used to access per-processor data structures in critical sections with enabled thread dispatching, e.g. a pinned thread is allowed to block. Update #3508.
* score: Generalize SMP scheduler block supportSebastian Huber2018-09-031-7/+12
| | | | | | Add extract from scheduled function to the _Scheduler_SMP_Block() operation. This allows a scheduler implementation to do extra work in case a scheduled node is blocked.
* Remove make preinstallChris Johns2018-01-251-0/+1482
