path: root/cpukit/include/rtems/score/schedulersimplesmp.h (follow)
* doxygen: score: adjust doc in schedulersimplesmp.h to doxygen guidelinesAndreas Dachsberger2019-05-131-2/+86
| | | | Update #3706.
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-3/+3
| | | | Update #3706
* score: Add thread pin/unpin supportSebastian Huber2018-09-101-1/+3
| | | | | | | | | Add support to temporarily pin a thread to its current processor. This may be used to access per-processor data structures in critical sections with enabled thread dispatching, e.g. a pinned thread is allowed to block. Update #3508.
* Remove make preinstallChris Johns2018-01-251-0/+155
