path: root/cpukit/include/rtems/score/schedulersimpleimpl.h (unfollow)
2018-01-25Remove make preinstallChris Johns1-0/+0
2017-11-20score: Optimize scheduler priority updatesSebastian Huber1-43/+9
Thread priority changes may append or prepend the thread to its priority group on the scheduler ready queue. Previously, a separate priority value and a prepend-it flag in the scheduler node were used to propagate a priority change to the scheduler. Now, use an append-it bit in the priority control and reduce the plain priority value to 63 bits. This change leads to a significant code size reduction (about 25%) of the SMP schedulers. The negligible increase of the standard priority scheduler is due to some additional shift operations (SCHEDULER_PRIORITY_MAP() and SCHEDULER_PRIORITY_UNMAP()). Before: text filename 136 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleblock.o 464 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimplechangepriority.o 24 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimple.o 108 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleschedule.o 292 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleunblock.o 264 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleyield.o text filename 280 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityblock.o 488 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerprioritychangepriority.o 200 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriority.o 164 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityschedule.o 328 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityunblock.o 200 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityyield.o text filename 24112 arm-rtems5/c/imx7/cpukit/score/src/libscore_a-scheduleredfsmp.o text filename 37204 sparc-rtems5/c/gr740/cpukit/score/src/libscore_a-scheduleredfsmp.o text filename 42236 powerpc-rtems5/c/qoriq_e6500_32/cpukit/score/src/libscore_a-scheduleredfsmp.o After: text filename 136 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleblock.o 272 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimplechangepriority.o 24 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimple.o 108 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleschedule.o 292 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleunblock.o 264 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleyield.o text filename 280 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityblock.o 488 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerprioritychangepriority.o 208 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriority.o 164 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityschedule.o 332 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityunblock.o 200 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityyield.o text filename 18860 arm-rtems5/c/imx7/cpukit/score/src/libscore_a-scheduleredfsmp.o text filename 28520 sparc-rtems5/c/gr740/cpukit/score/src/libscore_a-scheduleredfsmp.o text filename 32664 powerpc-rtems5/c/qoriq_e6500_32/cpukit/score/src/libscore_a-scheduleredfsmp.o
2017-11-06score: _Chain_Insert_ordered_unprotected()Sebastian Huber1-12/+26
Change the chain order relation to use a directly specified left hand side value. This is similar to _RBTree_Insert_inline() and helps the compiler to better optimize the code.
2016-11-02score: Pass scheduler node to block operationSebastian Huber1-1/+3
Changed for consistency with other scheduler operations. Update #2556.
2016-09-08score: Introduce _Thread_Get_priority()Sebastian Huber1-2/+4
Avoid direct access to thread internal data fields.
2014-05-15score: Simplify _Thread_Change_priority()Sebastian Huber1-18/+10
The function to change a thread priority was too complex. Simplify it with a new scheduler operation. This increases the average case performance due to the simplified logic. The interrupt disabled critical section is a bit prolonged since now the extract, update and enqueue steps are executed atomically. This should however not impact the worst-case interrupt latency since at least for the Deterministic Priority Scheduler this sequence can be carried out with a wee bit of instructions and no loops. Add _Scheduler_Change_priority() to replace the sequence of - _Thread_Set_transient(), - _Scheduler_Extract(), - _Scheduler_Enqueue(), and - _Scheduler_Enqueue_first(). Delete STATES_TRANSIENT, _States_Is_transient() and _Thread_Set_transient() since this state is now superfluous. With this change it is possible to get rid of the SCHEDULER_SMP_NODE_IN_THE_AIR state. This considerably simplifies the implementation of the new SMP locking protocols.
2014-05-14score: Add and use _Scheduler_Get_context()Sebastian Huber1-1/+1
2014-05-14score: Scheduler documentationSebastian Huber1-1/+1
2014-04-15score: Static scheduler configurationSebastian Huber1-11/+11
Do not allocate the scheduler control structures from the workspace. This is a preparation step for configuration of clustered/partitioned schedulers on SMP.
2014-04-04score: Add scheduler control to scheduler opsSebastian Huber1-8/+11
Scheduler operations must be free of a global scheduler context to enable partitioned/clustered scheduling.
2014-04-04score: Add and use Scheduler_simple_ControlSebastian Huber1-3/+7
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns1-1/+1
2013-08-20score: PR2136: Fix _Thread_Change_priority()Sebastian Huber1-1/+15
Add call to _Scheduler_Schedule() in missing path after _Thread_Set_transient() in _Thread_Change_priority(). See also sptests/spintrcritical19. Add thread parameter to _Scheduler_Schedule(). This parameter is currently unused but may be used in future SMP schedulers. Do heir selection in _Scheduler_Schedule(). Use _Scheduler_Update_heir() for this in the particular scheduler implementation. Add and use _Scheduler_Generic_block().
2013-07-26score: Create schedulerpriority impl headerSebastian Huber1-0/+2
Move implementation specific parts of schedulerpriority.h and schedulerpriority.inl into new header file schedulerpriorityimpl.h. The schedulerpriority.h contains now only the application visible API. Add missing includes. Remove superfluous includes. Move declaration of _Priority_Bit_map to prioritybitmap.inl since this variable is used only here. Remove second declaration of _Priority_Major_bit_map.
2013-07-26score: Create schedulersimple impl headerSebastian Huber1-6/+10
Move implementation specific parts of schedulersimple.h and schedulersimple.inl into new header file schedulersimpleimpl.h. The schedulersimple.h contains now only the application visible API.
2013-06-14scheduler: Simplify simple schedulerSebastian Huber1-0/+46
Add and use _Scheduler_simple_Insert_priority_fifo_order(), _Scheduler_simple_Insert_priority_lifo_order(), _Scheduler_simple_Insert_priority_fifo() and _Scheduler_simple_Insert_priority_lifo().
2013-01-10cpukit: Use Consistent Beginning of Doxygen Group NotationJoel Sherrill1-2/+1
This is the result of a sed script which converts all uses of @{ into a consistent form.
2013-01-09score: Doxygen Clean Up Task #18Alex Ivanov1-9/+13
http://www.google-melange.com/gci/task/view/google/gci2012/8137204
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill1-2/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2011-05-172011-05-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-1/+1
* score/inline/rtems/score/schedulersimple.inl, score/src/schedulersimpleyield.c: Fix violations of naming convention.
2011-05-122011-05-12 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill1-1/+1
* score/include/rtems/score/schedulersimple.h, score/inline/rtems/score/schedulersimple.inl, score/src/schedulersimpleenqueue.c, score/src/schedulersimpleenqueuefirst.c, score/src/schedulersimplereadyqueueenqueue.c, score/src/schedulersimplereadyqueueenqueuefirst.c, score/src/schedulersimpleunblock.c: Correct names as pointed out by Gedare.
2011-03-162011-03-16 Jennifer Averett <jennifer.averett@OARcorp.com>Joel Sherrill1-0/+53
PR 1743/cpu * sapi/include/confdefs.h, score/Makefile.am, score/preinstall.am: Add Simple Priority Scheduler as complement to existing Deterministic Priority Scheduler. This scheduler serves both as an example and as a lighter weight implementation for smaller systems. * score/include/rtems/score/schedulersimple.h, score/inline/rtems/score/schedulersimple.inl, score/src/schedulersimple.c, score/src/schedulersimpleblock.c, score/src/schedulersimpleenqueue.c, score/src/schedulersimpleenqueuefirst.c, score/src/schedulersimpleextract.c, score/src/schedulersimplereadyqueueenqueue.c, score/src/schedulersimplereadyqueueenqueuefirst.c, score/src/schedulersimpleschedule.c, score/src/schedulersimpleunblock.c, score/src/schedulersimpleyield.c: New files.
