Update #3706.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Thread priority changes may append or prepend the thread to its priority
group on the scheduler ready queue. Previously, a separate priority
value and a prepend-it flag in the scheduler node were used to propagate
a priority change to the scheduler.
Now, use an append-it bit in the priority control and reduce the plain
priority value to 63 bits.
This change leads to a significant code size reduction (about 25%) of
the SMP schedulers. The negligible increase of the standard priority
scheduler is due to some additional shift operations
(SCHEDULER_PRIORITY_MAP() and SCHEDULER_PRIORITY_UNMAP()).
Before:
text filename
136 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleblock.o
464 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimplechangepriority.o
24 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimple.o
108 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleschedule.o
292 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleunblock.o
264 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleyield.o
text filename
280 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityblock.o
488 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerprioritychangepriority.o
200 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriority.o
164 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityschedule.o
328 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityunblock.o
200 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityyield.o
text filename
24112 arm-rtems5/c/imx7/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
37204 sparc-rtems5/c/gr740/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
42236 powerpc-rtems5/c/qoriq_e6500_32/cpukit/score/src/libscore_a-scheduleredfsmp.o
After:
text filename
272 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimplechangepriority.o
text filename
208 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriority.o
332 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityunblock.o
text filename
18860 arm-rtems5/c/imx7/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
28520 sparc-rtems5/c/gr740/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
32664 powerpc-rtems5/c/qoriq_e6500_32/cpukit/score/src/libscore_a-scheduleredfsmp.o
In SMP configurations, add a red-black tree node to Scheduler_Node to
enable an EDF scheduler implementation.
Update #3056.
Update #2556.
Update #2556.
Update #2556.
Add the ability to add/remove scheduler nodes to/from the set of
scheduler nodes available to the schedulers for a particular thread.
Update #2556.
Maintain the priority of a thread for each scheduler instance via the
thread queue enqueue, extract, priority actions and surrender
operations. This replaces the primitive priority boosting.
Update #2556.
Update #2556.
Update #2556.
* _Thread_Priority_add(),
* _Thread_Priority_remove(),
* _Thread_Priority_update().
Update #2412.
Update #2556.
Update #2556.
Update #2556.
This makes it possible to add scheduler nodes to structures defined in
<rtems/score/thread.h>.
Update #2556.
