path: root/cpukit/include/rtems/score/schedulercbs.h (follow)
* cpukit/include/rtems/score/[s-z]*.h: Change license to BSD-2Joel Sherrill2022-02-281-3/+22
| | | | Updates #3053.
* score: Introduce CPU budget operationsSebastian Huber2021-11-151-9/+2
| | | | | | | | | | | | | | This patch set replaces the CPU budget algorithm enumeration with a set of CPU budget operations which implement a particular CPU budget algorithm. This helps to hide the CPU budget algorithm implementation details from the general thread handling. The CPU budget callouts are turned into CPU budget operations. This slightly reduces the size of the thread control block. All schedulers used the default scheduler tick implementation. The tick scheduler operation is removed and the CPU budget operations are directly used in _Watchdog_Tick() if the executing thread uses a CPU budget algorithm. This is performance improvement for all threads which do not use a CPU budget algorithm (default behaviour).
* score: SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITYSebastian Huber2021-09-211-1/+1
| | | | | Rename SCHEDULER_OPERATION_DEFAULT_GET_SET_AFFINITY in SCHEDULER_DEFAULT_SET_AFFINITY_OPERATION. Add Doxygen comment.
* score: SCHEDULER_OPERATION_DEFAULT_ASK_FOR_HELPSebastian Huber2021-09-211-1/+1
| | | | | Rename SCHEDULER_OPERATION_DEFAULT_ASK_FOR_HELP in SCHEDULER_DEFAULT_SMP_OPERATIONS. Add a Doxygen comment.
* score: Canonicalize Doxygen @file commentsSebastian Huber2020-12-021-4/+3
| | | | | | Use common phrases for the file brief descriptions. Update #3706.
* score: Canonicalize Doxygen groupsSebastian Huber2020-12-021-2/+3
| | | | | | | Adjust group identifier and names to be in line with a common pattern. Use common phrases for the group brief descriptions. Update #3706.
* doxygen: score: adjust doc in schedulercbs.h to doxygen guidelinesAndreas Dachsberger2019-05-131-55/+138
| | | | Update #3706.
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-2/+2
| | | | Update #3706
* Remove explicit file names from @fileSebastian Huber2019-02-281-1/+1
| | | | | | This makes the @file documentation independent of the actual file name. Update #3707.
* Remove make preinstallChris Johns2018-01-251-0/+346
