path: root/cpukit/include/rtems/score/processormask.h (follow)
* score: Account for <sys/bitset.h> API changesSebastian Huber2022-06-231-17/+73
| | | | Update #4667.
* score: Remove unused _Processor_mask_Nand()Sebastian Huber2022-06-231-16/+0
| | | | Update #4667.
* cpukit/: Scripted embedded brains header file clean upJoel Sherrill2022-03-101-6/+0
| | | | Updates #4625.
* cpukit/include/rtems/score/[a-r]*.h: Change license to BSD-2Joel Sherrill2022-02-281-3/+22
| | | | Updates #3053.
* score: Canonicalize Doxygen @file commentsSebastian Huber2020-12-021-2/+3
| | | | | | Use common phrases for the file brief descriptions. Update #3706.
* score: Canonicalize Doxygen groupsSebastian Huber2020-12-021-1/+1
| | | | | | | Adjust group identifier and names to be in line with a common pattern. Use common phrases for the group brief descriptions. Update #3706.
* doxygen: score: adjust doc in processormask.h to doxygen guidelinesAndreas Dachsberger2019-05-131-6/+169
| | | | Update #3706.
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-3/+3
| | | | Update #3706
* Remove make preinstallChris Johns2018-01-251-0/+290
