* | cpukit/: Scripted embedded brains header file clean up | Joel Sherrill | 2022-03-10 | 1 | -6/+0 |
| | | | | Updates #4625. | ||||
* | cpukit/include/rtems/score/[a-r]*.h: Change license to BSD-2 | Joel Sherrill | 2022-02-28 | 1 | -3/+22 |
| | | | | Updates #3053. | ||||
* | score: Add PER_CPU_DATA_NEED_INITIALIZATION() | Sebastian Huber | 2021-06-10 | 1 | -0/+14 |
| | | | | | | | | | Make the initialization of the per-CPU data optional. Change license to BSD-2-Clause according to file history and re-licensing agreement. Update #3053. | ||||
* | score: Canonicalize Doxygen @file comments | Sebastian Huber | 2020-12-02 | 1 | -1/+2 |
| | | | | | | Use common phrases for the file brief descriptions. Update #3706. | ||||
* | score: Canonicalize Doxygen groups | Sebastian Huber | 2020-12-02 | 1 | -7/+8 |
| | | | | | | | Adjust group identifier and names to be in line with a common pattern. Use common phrases for the group brief descriptions. Update #3706. | ||||
* | score: Fix linker sets on small data area targets | Sebastian Huber | 2020-02-06 | 1 | -2/+1 |
| | | | | Update #3865. | ||||
* | doxygen: score: adjust doc in percpudata.h to doxygen guidelines | Andreas Dachsberger | 2019-05-13 | 1 | -0/+2 |
* | doxygen: score: adjust doc in percpudata.h to doxygen guidelines | Andreas Dachsberger | 2019-05-13 | 1 | -0/+8 |
* | score: Fix PER_CPU_DATA_ITEM_DECLARE() | Sebastian Huber | 2018-09-17 | 1 | -1/+2 |
| | | | | | | Fix PER_CPU_DATA_ITEM_DECLARE() for targets with a small-data area. Update #3507. | ||||
* | score: Fix PER_CPU_DATA_GET_BY_OFFSET() | Sebastian Huber | 2018-09-10 | 1 | -1/+7 |
| | | | | | | | Add uniprocessor version for PER_CPU_DATA_GET_BY_OFFSET(). Fix warnings in uniprocessor configurations. Update #3507. | ||||
* | score: Add flexible per-CPU data | Sebastian Huber | 2018-09-10 | 1 | -0/+104 |
Update #3507. |
