* | posix: Remove unused OBJECTS_POSIX_INTERRUPTS | Sebastian Huber | 2019-05-20 | 1 | -1/+0 |
* | doxygen: Rename Score* groups in RTEMSScore* | Sebastian Huber | 2019-04-04 | 1 | -2/+2 |
| | | | | Update #3706 | ||||
* | score: Update Objects_Information documentation | Sebastian Huber | 2019-03-22 | 1 | -36/+115 |
* | score: Static Objects_Information initialization | Sebastian Huber | 2018-12-14 | 1 | -1/+182 |
| | | | | | | | | | | | Statically allocate the objects information together with the initial set of objects either via <rtems/confdefs.h>. Provide default object informations with zero objects via librtemscpu.a. This greatly simplifies the workspace size estimate. RTEMS applications which do not use the unlimited objects option are easier to debug since all objects reside now in statically allocated objects of the right types. Close #3621. | ||||
* | score: Move internal structures to objectdata.h | Sebastian Huber | 2018-11-12 | 1 | -0/+98 |
Update #3598. |
