path: root/cpukit/include/rtems/score/muteximpl.h (follow)
* cpukit/: Scripted embedded brains header file clean upJoel Sherrill2022-03-101-6/+0
| | | | Updates #4625.
* cpukit/include/rtems/score/[a-r]*.h: Change license to BSD-2Joel Sherrill2022-02-281-3/+22
| | | | Updates #3053.
* score: Canonicalize Doxygen @file commentsSebastian Huber2020-12-021-9/+16
| | | | | | Use common phrases for the file brief descriptions. Update #3706.
* doxygen: score: adjust doc in muteximpl.h to doxygen guidelinesAndreas Dachsberger2019-05-131-0/+16
| | | | Update #3706.
* Remove make preinstallChris Johns2018-01-251-0/+37
