path: root/cpukit/include/rtems/score/muteximpl.h (follow)
* score: Canonicalize Doxygen @file commentsSebastian Huber2020-12-021-9/+16
| | | | | | Use common phrases for the file brief descriptions. Update #3706.
* doxygen: score: adjust doc in muteximpl.h to doxygen guidelinesAndreas Dachsberger2019-05-131-0/+16
| | | | Update #3706.
* Remove make preinstallChris Johns2018-01-251-0/+37
