path: root/cpukit/include/rtems/score/isrlock.h (follow)
* cpukit/: Scripted embedded brains header file clean upJoel Sherrill2022-03-101-6/+0
| | | | Updates #4625.
* cpukit/include/rtems/score/[a-r]*.h: Change license to BSD-2Joel Sherrill2022-02-281-3/+22
| | | | Updates #3053.
* score: Canonicalize Doxygen @file commentsSebastian Huber2020-12-021-1/+2
| | | | | | Use common phrases for the file brief descriptions. Update #3706.
* score: Canonicalize Doxygen groupsSebastian Huber2020-12-021-4/+6
| | | | | | | Adjust group identifier and names to be in line with a common pattern. Use common phrases for the group brief descriptions. Update #3706.
* doxygen: score: adjust doc in isrlock.h to doxygen guidelinesAndreas Dachsberger2019-05-131-2/+2
| | | | Update #3706.
* score: Add _ISR_lock_Set_name()Sebastian Huber2019-04-121-0/+15
| | | | | Add _ISR_lock_Set_name() to optimize the initialization of zero-initialized locks.
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-3/+3
| | | | Update #3706
* score: Remove unused _ISR_lock_Flash()Sebastian Huber2019-01-181-31/+0
* score: Improve debug support for ISR locksSebastian Huber2019-01-181-13/+19
| | | | Ensure that interrupts are disabled while acquiring an ISR lock.
* Remove make preinstallChris Johns2018-01-251-0/+439
