path: root/cpukit/include/rtems/score/freechain.h (follow)
* score: Canonicalize Doxygen @file commentsSebastian Huber2020-12-021-1/+4
| | | | | | Use common phrases for the file brief descriptions. Update #3706.
* score: Canonicalize Doxygen groupsSebastian Huber2020-12-021-4/+4
| | | | | | | Adjust group identifier and names to be in line with a common pattern. Use common phrases for the group brief descriptions. Update #3706.
* score: Add <rtems/score/freechainimpl.h>Sebastian Huber2020-08-311-123/+1
| | | | | | Hide implementation details. Update #3959.
* score: Add _Freechain_Push()Sebastian Huber2020-08-311-2/+17
| | | | Update #3959.
* score: Add _Freechain_Extend()Sebastian Huber2020-02-121-0/+18
| | | | Update #3835.
* score: Add _Freechain_Pop()Sebastian Huber2020-02-121-0/+12
| | | | Update #3835.
* score: Add _Freechain_Is_empty()Sebastian Huber2020-02-121-0/+12
| | | | Update #3835.
* doxygen: score: adjust doc in freechain.h to doxygen guidelinesAndreas Dachsberger2019-05-131-12/+14
| | | | Update #3706.
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-3/+3
| | | | Update #3706
* score: Static Objects_Information initializationSebastian Huber2018-12-141-5/+13
| | | | | | | | | | | Statically allocate the objects information together with the initial set of objects either via <rtems/confdefs.h>. Provide default object informations with zero objects via librtemscpu.a. This greatly simplifies the workspace size estimate. RTEMS applications which do not use the unlimited objects option are easier to debug since all objects reside now in statically allocated objects of the right types. Close #3621.
* Remove make preinstallChris Johns2018-01-251-0/+111
