path: root/cpukit/include/rtems/score/freechain.h (unfollow)
2019-05-13doxygen: score: adjust doc in freechain.h to doxygen guidelinesAndreas Dachsberger1-12/+14
Update #3706.
2019-04-04doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber1-3/+3
Update #3706
2018-12-14score: Static Objects_Information initializationSebastian Huber1-5/+13
Statically allocate the objects information together with the initial set of objects either via <rtems/confdefs.h>. Provide default object informations with zero objects via librtemscpu.a. This greatly simplifies the workspace size estimate. RTEMS applications which do not use the unlimited objects option are easier to debug since all objects reside now in statically allocated objects of the right types. Close #3621.
2018-01-25Remove make preinstallChris Johns1-0/+0
2015-07-01score: Accept NULL pointer in _Freechain_Put()Sebastian Huber1-1/+2
With this a _Freechain_Put( _Freechain_Get() ) works always.
2015-07-01score: Freechain handler API changesSebastian Huber1-26/+28
Replace the extend function with an allocator since this fits better to the current use case.
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns1-1/+1
2013-07-24score: Add freechainZhongwei Yao1-0/+108
