path: root/cpukit/include/rtems/score/coresemimpl.h (follow)
* score: Canonicalize Doxygen @file commentsSebastian Huber2020-12-021-4/+2
| | | | | | Use common phrases for the file brief descriptions. Update #3706.
* doxygen: score: adjust doc in coresemimpl.h to doxygen guidelinesAndreas Dachsberger2019-05-131-26/+63
| | | | Update #3706.
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-1/+1
| | | | Update #3706
* Remove make preinstallChris Johns2018-01-251-0/+207
