path: root/cpukit/include/rtems/score/corerwlockimpl.h (follow)
* score: Canonicalize Doxygen @file commentsSebastian Huber2020-12-021-4/+2
| | | | | | Use common phrases for the file brief descriptions. Update #3706.
* score: Canonicalize Doxygen groupsSebastian Huber2020-12-021-5/+6
| | | | | | | Adjust group identifier and names to be in line with a common pattern. Use common phrases for the group brief descriptions. Update #3706.
* doxygen: score: adjust doc in corerwlockimpl.h to doxygen guidelinesAndreas Dachsberger2019-05-131-16/+52
| | | | Update #3706.
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-2/+2
| | | | Update #3706
* doxygen: score: Added ScoreRWLock to Score groupAndreas Dachsberger2019-04-021-5/+9
| | | | Update #3706.
* Remove make preinstallChris Johns2018-01-251-0/+182
