path: root/cpukit/include/rtems/score/coremutex.h (follow)
* cpukit/include/rtems/score/[a-r]*.h: Change license to BSD-2Joel Sherrill2022-02-281-3/+22
| | | | Updates #3053.
* score: Canonicalize Doxygen @file commentsSebastian Huber2020-12-021-7/+6
| | | | | | Use common phrases for the file brief descriptions. Update #3706.
* score: Canonicalize Doxygen groupsSebastian Huber2020-12-021-1/+1
| | | | | | | Adjust group identifier and names to be in line with a common pattern. Use common phrases for the group brief descriptions. Update #3706.
* doxygen: score: adjust doc in coremutex.h to doxygen guidelinesAndreas Dachsberger2019-05-131-6/+11
| | | | Update #3706.
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-2/+2
| | | | Update #3706
* Remove make preinstallChris Johns2018-01-251-0/+104
