path: root/cpukit/include/rtems/score/corebarrierimpl.h (follow)
* cpukit/include/rtems/score/[a-r]*.h: Change license to BSD-2Joel Sherrill2022-02-281-3/+22
| | | | Updates #3053.
* score: Remove _CORE_barrier_Do_flush()Sebastian Huber2021-02-241-17/+6
| | | | Call _Thread_queue_Flush_critical() directly.
* score: Simplify core barrierSebastian Huber2021-02-241-42/+14
| | | | | | Use the number of threads which must arrive at the barrier to trip the automatic release also to indicate if the barrier is a manual release barrier.
* score: Add barrier thread queue operationsSebastian Huber2021-02-061-1/+8
| | | | | | | This fixes a missing decrement of the number of waiting threads during a barrier wait timeout. Close #4230.
* score: Canonicalize Doxygen @file commentsSebastian Huber2020-12-021-4/+2
| | | | | | Use common phrases for the file brief descriptions. Update #3706.
* doxygen: score: adjust doc in corebarrierimpl.h to doxygen guidelinesAndreas Dachsberger2019-05-131-24/+65
| | | | Update #3706.
* doxygen: Rename Score* groups in RTEMSScore*Sebastian Huber2019-04-041-1/+1
| | | | Update #3706
* Remove make preinstallChris Johns2018-01-251-0/+173
